IF you have leaf spring suspension, you can move the axles from on top to below the axles IN THE SAME ORIENTATION, called flipping the axle. It requires a new set of axle mounts, bought as a pair per axle for that specific diameter axle. You would gain about 5”. A competent mechanic can do it. Many people do their own.
New larger tires and wheels would now fit and gain more clearance. Bumping an inch in wheel diameter and using larger tires gains you about 1” more. This is more costly.
My single axle flip cost me about $65 for the new axle mounts and $200 labor.
2019 Cherokee Wolf Pup 16BHS flipped axle
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars, SumoSprings
