04-07-2021, 11:16 PM
Brought home new TT tonight. Drug the back end. :-(
Brought home a new 37 Foot Travel Trailer this evening. When pulling into the storage lot, it’s a pretty steep grade, at an angle I drug and bent the rear bumper and even the spare tire mount. I’ve seen wheels mounted below the trailers before, is this what I should be looking at?
I’ve had trailers before but never this long. Should I look for a bolt on set? Some of the reviews show these wheels don’t really hold up.
Thoughts? I’m lost.
04-08-2021, 01:48 AM
Thoughts? I’m lost.
Anything you "Bolt/weld/add to your rear Frame will come in contact with the Ground/Road sooner than what you have now"! Wheels/skid pads added might add to Bending of the Frame! Youroo!!
04-08-2021, 06:59 AM
I mounted the spare below the front pass thru storage on a Rockwood Ultra lite.
Your answer is really- avoid dragging. You have a trailer not that much smaller than some house trailers. You'll have to be super cautious around any turn in or out that's got much of any grade.
I'm surprised it was the bumper as it's often the dump valves that get
damaged when a long rig meets a steep turn in. Hope it's not too bad!
Peace!
Dan & Rita D
04-08-2021, 09:56 PM
Thank goodness the dump valves are much further forward on this TT.
04-09-2021, 01:26 PM
the problem with rear dolly wheels are the tend to try to lift the back of the trailer leaving the axel area suspended off the ground in that situation which could bend the frame
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
04-09-2021, 02:15 PM
The longer the RV, the more any small incline will drag. Try gas stations. Best go into them at a slow angle. I have experienced tail drag on many RVs.
2019 Forester 2861DS
04-09-2021, 03:51 PM
Been there, got the T-Shirt. First increase the angle and go super slow regardless of traffic. The other advice you've received is spot on. Possibly carrying some 2X6 pieces to act as a ramp under the trailer wheels would work. Very often it's the stabilizer jacks that get bent 90 degrees, ask me how I know.
Paul
Paul / Carole Ann and 'Monte' the Goldendoodle
2020 Rockwood Mini Lite 2511S
2017 Rockwood Mini Lite 2502KS
2005 Tiffin Allegro Bus 40TSP
2012 Ram 2500 6.7L Diesel
04-09-2021, 04:32 PM
How about doing an axel flip? If you travel this road or similar a lot
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47
04-09-2021, 04:50 PM
Exactly what they are saying. You just have to learn by trial and error on how to approach a steep grade. With a TT that long it will be tough but you will get the hang of it.
The frames under these TT's today are pretty weak not like yesteryear when they were not worried about weight.
Unless the OP provides year, make and model number of trailer, we don't know whether it has torsion axles or conventional axles. Torsion axles can't be flipped.
04-09-2021, 05:04 PM
The first time I took my trailer to a campground my leveling jacks stopped me dead in my tracks when they caught on 1/2 bump in the concrete pad and the incline wasn't that much. I raised all my levelers to their highest position and haven't drug since. Is you trailer level or is the front higher when you are on level ground? If it is lower the front. I also put bigger tires on my trailer to raise the whole trailer. Someone said if you put wells on the back it could it lift the tires off the ground and bend the frame... I find that very hard to believe, they may raise the trailer body, but not enough to lift the wheels off the ground. Have fun finding a solution, it's out there!
Max & Tina
2016 Prime Time
Spartan Toy Hauler
43 feet
04-09-2021, 07:26 PM
On a 37-footer?
Do they put torsion axles on 37-footers? I somehow got the impression that they were used on smaller units?
Larry
"Everybody's trailer is not like your trailer."
04-09-2021, 09:08 PM
Camping with Labs
Our TT is nearly 37' long, end-to-end, and it has torsion axles.
Chris, Paula, & camping Labs, Shasta (RIP 8/10/20) & Cammie
2005 Yukon XL 2500 with 8.1 Engine, Allison Transmission, and 3.73 Axle Ratio
2019 Rockwood Signature 8335BSS with Hensley Arrow Hitch
04-09-2021, 09:53 PM
Before you do ANY modification to your trailer, if it's new and has a manufacturer's warranty, check and see if the mod will void your warranty. Some of the Wolf Pups like we bought come with a factory fold-down rack on the rear bumper. In one manufacturer's video showing this feature, the spokesperson comments against any after-market add-ons, stating that anything welded or bolted into the rear bumper or frame will void the warranty.
Your dealer should be able to answer this question for you.
"We do not quit playing because we grow old. We grow old because we quit playing." ~ Oliver Wendell Holmes
2021 Wolf Pup 16FQ
2005 Toyota Sequoia
04-09-2021, 09:54 PM
Yes, yes they do.
Days Camped ☼ '19=110 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=110
04-09-2021, 10:49 PM
I have installed pneumatic castors on the back of every camper we have owned. They have saved us on numerous occasions when pulling off parking lots to crossing streams and gullies. On our current TT I have full swiveling 8” wheels. These protect my leveling jacks, dump valves, rear bumper, etc. First time out with our latest TT we were pulling across a small stream and all four wheels were off the ground, the rig was on the castors and hitch. When doing this GO SLOW!!!!
04-09-2021, 11:08 PM
Maybe dropping the hitch ball on the TV one notch will drop the trailer nose and raise the trailer tail an equal amount... if that does not interfere on the front clearance...
Or go from 15 inch tires to 16 inch wheels and tires... won't gain you much for probably a big expense..
finally a different storage location
2014 Shamrock 183
04-10-2021, 03:42 AM
Camping the Natural State
Try to go across the dip at an angle.
2021 Rockwood Ultra Lite 2614 BS
04-11-2021, 03:09 PM
2021 Salem 29VBUD. I have no clue if a axel flip can be done. Would the dealer do that?
04-11-2021, 03:12 PM
This is most likely going to happen. I’ll try it a couple times at an angle but it’s a steep hill, and I can’t justify tearing things up. I’ve had TT’s for 10 years and only once have I drug anything in the back. The length of this new one doesn’t help me at all.
