Old 05-30-2017, 06:32 PM   #1
Camper & backup cam have different plugs
Hi all, I am new to this site.
I recently purchased a 2017 Salem Cruise Lite prepped with the backup camera mount and just the other day I purchased a Furrion Observation camera. I attempted to install the camera today (attempted being the key word). The plug on my Cruise Lite looks like the power plug used for PADS and other electronic devices and the one for the camera looks like the plug used for the ear piece used for the good ole transistor radios.
Has anyone else ran into this problem and what did you do?
Thanks in advance for any and all help!
ID:	139599   Click image for larger version
MoCamper55 is offline   Reply With Quote
Old 05-30-2017, 07:16 PM   #2
Your Salem was probably wired for a Drive CL-718W. Our Wildwood was wired for that camera and not the Furrion.
Bobkaren is offline   Reply With Quote
Old 06-01-2017, 04:38 PM   #3
No ideas yet? Only think I can think of is to cut the plugs off and hard wire them together. Any thoughts on this idea?
Old 06-02-2017, 08:14 PM   #4
RangeMaggotBob's Avatar
That is not a good idea. See post #2.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
And new to our family: Daisy May, the Golden Doodle wonderdog!
RangeMaggotBob is offline   Reply With Quote
Old 06-05-2017, 07:13 PM   #5
I was able to tie into the running light and everything works perfect. I used a heat gun and wire shrink tubing to make all connections water tight.
Old 06-05-2017, 07:35 PM   #6
All well and good but.... He already has the Furrion (which I personally think is a better unit anyway) so, cut the wires, strip the insulation, slip on some heat shrrik tubing, solder the ends, slide the heat shrink over the soldered connections, heat to shrink and call it good.
SidecarFlip is offline   Reply With Quote
camper
