06-06-2017, 07:11 PM
Can I leave my fifth wheel attached to TV
Can I leave my fifth wheel attached to TV overnight? Should I still try to level and should I put down stabilizer jack and front leveling jacks? Also if not hooked up to electric will battery of RV drain my TV battery. Thanks. Asking for when we are on the road and only making quick overnight stops.
Rockwood ultra lite 2440ws
2014 Toyota Tundra 4wd v8 5.7
reese hitch
reese revolution on rv
06-06-2017, 07:23 PM
You should not be that far off level if your hitch is set up right. You can not run adsorption fridge if you are not fairly close to level. Depending on what is running in the 5er and what TV you have, you can kill the TV battery as well if you do not unhook the Bargman. Some TV include a relay that only activates the 12V aux line ( pin ) when the ignition is on. In others, it is a direct connection to the Battery through a fuse and can drain the battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-06-2017, 07:25 PM
I leave mine hooked up but unplug from truck to be sure truck starts in morning.
06-07-2017, 05:00 AM
Same here but will put the front legs down to help steady the camper.
06-07-2017, 05:51 AM
You have a 2509 Mini Lite Travel Trailer? Youroo!!
06-07-2017, 06:29 AM
(Dry Huunday)
Hmmm...Under his profile he shows a 2440WS fifth wheel....
Maybe he replaced the TT? Typo in the signature? Or heck maybe he owns two!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
06-07-2017, 06:43 AM
I had purchased a 2509s but it was totaled while being delivered. Bought the 2440ws instead. First 5er
reese hitch
06-07-2017, 06:52 AM
It wasn't that way 5 min ago! I think he just did a "Update"! Youroo!!
06-07-2017, 07:01 AM
(Dry Huunday)
OUCH! What a way to start out! Hope everything is working out for you and happy travels!
Beau & Sue
FurKid Express
06-07-2017, 07:38 AM
I have a TT, but it applies the same. I leave it hooked when just overnighting at Walmart. I park nose down and use the jack to level. Within reason, of course. I put down stabilizers, too. I also have a charge controller I mounted in the truck, so I can leave it connected without issue.
WirthCo 20092 Battery Doctor 125 Amp/150 Amp Battery Isolator https://www.amazon.com/dp/B0058SGDFK..._0o.nzb22MSS2Q
06-07-2017, 01:10 PM
Newly Retired
Heck ya
I know people the disconnect religiously. Just want to practice I guess.
If you don't need your tow vehicle to go somewhere I see no reason to disconnect.
As far as leveling, you can use blocks under tires or your front jacks, or both.
It's not a bad idea to unplug your electrical to your tow vehicle whether you are connected to shore power or not.
06-07-2017, 01:40 PM
When we spend a quick night on the road I leave it hitched if there's room in the campsite. I'll level it as best I can with the front jacks to keep the fridge going and to stabilize it. Never had a problem with the TV battery which I keep connected.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
06-07-2017, 01:48 PM
I will be stopping in Petrolia Ontario tomorrow night and will stay hitched up! Have done it in the past! Might see a Frog or two there as well!
06-07-2017, 01:53 PM
On my fifth wheel I put the front jacks down to take the weight off the truck. I have a residential refrigerator so camper doesn't have to be level. I don't unplug the fifth wheel from truck as my Silverado has two batteries and the truck has battery has run down protective.
06-07-2017, 01:55 PM
I also just unplug from the truck. If I want more stability I only drop front landing gear.
2014 Coachmen Brookstone 325RL
2015 Chev Silverado 2500 Diesel.
06-07-2017, 02:07 PM
when we towed our windjammer across country, we used koa campgrounds which were close to I40, always used pull through sites. I stayed hooked up, put slides out, used stabilizers to steady the trailer. I stayed hook up to the truck via the power cord, however I always hooked up the shore power. I guess the TT likes 110volt more than 12volt. Did I hurt anything ??? I thought the 110 power on would not harm the 12 volt system. No issues with the dual battery system on my diesel. We left the campground first lite the next day. I saw other campers doing the same as they were travelling also.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
06-07-2017, 02:40 PM
You can stay hooked, i do it often when traveling. I put my stabilizers down to stop the rocking. [ don't for to raise them before leaving. ] Try to stay as level as possible to protect the refrigerator.
06-07-2017, 10:23 PM
New RV Owner
I installed a battery disconnect switch on my TT, can I assume I can just shut off the battery, or will it still drain the tv?
We are planning a long trip in August
Rob & Julie
2018 Coachmen Catalina 323BHDS
2016 Nissan NV Pass 3500HD
06-07-2017, 11:50 PM
Just to be sure just unplug tv power cord and use your trailer battery. You don't want to disconnect your camper battery, you need power for lights, water etc.
06-09-2017, 05:19 AM
Insert witty title here
I leave mine connected but will lower the tongue jack to take the weight off the truck.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
