Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-18-2021, 05:53 PM   #161
lesptr's Avatar
Originally Posted by PodGeek View Post
I checked out a 2018 RAM 2500 6.7L Cummins diesel last weekend. Payload a tad over 2000 lbs and the previous owner had put an auxiliary fuel tank in the bed and was set up to tow a fifth wheel. No, he wasn't over payload at all...
Most RAM gassers I've checked out lately are around 3000 lbs.
Verified by scales?
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 11-18-2021, 06:10 PM   #162
Originally Posted by lesptr View Post
Verified by scales?
Door sticker. Those diesel engines are heavy! Not being a diesel guy I had no idea.
PodGeek is offline   Reply With Quote
Old 11-18-2021, 06:34 PM   #163
SetauketJeff's Avatar
Originally Posted by D W View Post
X2 with today's disc brake set up. I do recall an occasion while in high school when I was driving home from work and my brake pedal went to the floor when the master cylinder failed on my 62 Chevy Impala. I had to drive about 5 miles holding the hand release for the emergency brake while depressing the emergency brake pedal to slow down and stop. It wasn't a fun ride, but it got me home.
Today's setups are different. Your 62, like my 1971 which I own today (with manual brakes and manual steering) used large rear drums that were hydraulic (ergo the master cylinder). The emergency brake is simply a cable run to activate the same drum brake should the hydraulics fail. It's also used when parking, when there is no hydraulic power to the brakes as the engine is not running and providing vacuum to the master cylinder.
Many of today's rear breaks (especially on Light Trucks and SUVs) have a rotor and a drum. The rotor (hydraulicly controlled disc brake) is used when driving, the internal drum, which is run either by cable or electric solenoid/motor (which is why you now need a scan tool to back-out some the brakes for service/removal) is used for emergency and parking. This internal drum is very small in diameter and width. The brake shoes are tiny, and therefor offer very little stopping power. In my opinion, they are tits on a bull....... useless.
Every stop light is a staging light!
2021 Wolf Pup 16FQ.
2007 Chevy Trailblazer LT 4X4 Tow Package, Locking Rear, 157K Just pulled 16FQ 1,044 miles. Husky Centerline TS32215 WDH Round Bar 400-600Lbs.
CURT 51180 Echo Bluetooth Brake Controller (Love it!)
2004 Ford F-150 STX 4X4 Tow Package, 206K For Pulling TT in the sand
SetauketJeff is offline   Reply With Quote
Old 11-18-2021, 06:35 PM   #164
lesptr's Avatar
If he didnít scale it. He does not know.
2015 F350 6.7
Old 11-18-2021, 07:08 PM   #165
No drums anymore. An electric motor also operates the disc caliper on my F150 which is why you need to put the brakes into service mode. Even my wife's '14 Ford Escape uses a cable that squeezes the rear calipers.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 11-23-2021, 03:36 PM   #166
NHP released some still photos from the intersection traffic cam.
Pre-impact photo clearly shows smoke coming from the brakes of the F350.
Impact images are brutal but it does confirm it was a Rivarama 44 sitting on a 5 axle trailer.
Official cause is brake failure and the driver remains in custody.
News story indicates the boat and trailer weighed 37,000 and the tow rating on the F350 was 21,000, mistakenly reported as payload in the story.
So very sad for the dead and injured.
https://www.ktvn.com/story/45154083/...in-carson-city
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 11-23-2021, 03:48 PM   #167
I think they still have the weights wrong. 2015 Rivarama Super 44 weighs in at 28,881 lbs:
https://specs.boatguideweb.com/speci...super_44/2015/
Does anyone really think that trailer weighs 10K lbs?
Previous news story indicates total weight of boat, trailer, and truck at ~38K lbs.
Also, looks like those skid marks reported upthread were already there when the ill-fated rig approached the intersection.
Old 11-23-2021, 03:56 PM   #168
Here's a photo of the trailer..it looks like it could weigh 10,000 unloaded.
Old 11-23-2021, 04:03 PM   #169
Maybe so. That's a pretty beefy trailer.
Old 11-23-2021, 04:43 PM   #170
It's an aluminum trailer, so not as heavy as you think, probably 4K or less. https://allmarinetrailers.net/traile...rd-and-custom/
Regardless, that is a CDL rated trailer, and should not have been behind that truck since it is only rated at 21,000 conventional, and that had to be at least 32K. In fact I am surprised that trailer was even used since it should be a gooseneck for that much weight.
The BEAST 2012 F350 King Ranch 6.7 Powerstroke
2020 Arctic Wolf 3660SUITE
Bhrava is offline   Reply With Quote
Old 11-23-2021, 07:30 PM   #171
Homebrew's Avatar
I guess the answer to the OP is yes it can tow 38k down hill but it canít stop!
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 11-23-2021, 08:12 PM   #172
Which would suggest that there have similar problems at this intersection but without tragic consequences.
If the warning signs are on the hill and people still go too fast then more enforcement would be in order. Even those flashing speed signs that tell drivers to slow.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-23-2021, 08:43 PM   #173
The armchair wizards got it wrong? You could knock me over with a feather...
Old 11-24-2021, 02:17 AM   #174
The idiot driver also bypassed the emergency runaway truck ramp that is about 300' from the stoplights.
Tundra 2017 CrewMax retired for a RAM Laramie 2500
FR 2017 T2460 EVO
Andersen sway control
Cahriad is offline   Reply With Quote
Old 11-24-2021, 07:16 AM   #175
asr524's Avatar
Did they move the run away ramp?
Google maps measures the ramp to be 2,500ft away....nearly a half mile!
2021 Wolfpack 315Pack12
2014 Ford F350 6.7L Diesel
2019 Indian Chieftain Dark Horse
asr524 is online now   Reply With Quote
Old 11-24-2021, 08:29 AM   #176
If you're going fast enough that 2500ft may just seem like only 300ft.
2004 Nissan Titan
Old 11-24-2021, 10:43 AM   #177
Cabinfever97's Avatar
I dont know about anyone else that tows often, I tow all the time for work plus the camper. I have a plan in my head incase brakes fail. Even if everything is in great working order, not over loaded, etc failures still happen. Even if I missed that run away ramp there is plenty of space to run off the road and not crash through an intersection. I would try and get stopped by crashing in a "better" place before running through an intersection.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
Hensley Hitch
Cabinfever97 is offline   Reply With Quote
Old 11-24-2021, 12:29 PM   #178
Regarding the actual weight of the boat and trailer, the 28,800 lbs that has been previously referenced is the ďdryĒ weight of the boat. It appears that a fully loaded boat can weight much more, in this case ~34,178 lbs.
https://www.powerandmotoryacht.com/b...iva-rivarama-1
Forellan is offline   Reply With Quote
Old 11-24-2021, 01:13 PM   #179
Homebrew's Avatar
weíre still on the weight of the boat and trailer?
The guy didnít have a license!!!!
2014 Ram 3500 DRW
Old 11-24-2021, 01:21 PM   #180
Originally Posted by TitanMike View Post
What you said PLUS the fact that most steep downgrades have a "Brake Check" area just before the grade begins. The idea is to stop, make sure all connections that make your brakes work are connected (electrical or air) and even go so far as activating the trailer brakes, trying to move trailer with them activated, and if all is well THEN start down the hill.
Too much trouble you say? Take the time and trouble at the top and the likelihood you'll have a BIG problem at the bottom of the hill is greatly reduced.
On the long steep grades I like to just stay behind a big truck that's slowly descending the hill. Not only easier on MY brakes going that slow, but if they do heat and fade I can use the rear of the big truck to slow/stop me rather than gaining speed and have a much bigger accident farther down the hill.
Those areas also serve as a good place to get into a reduced gear for the decent. In PA many have requirements for vehicles over a certain weight to observe a lower speed limit on the decent.
Tow vehicle 2021 F-250
TT Apex 256BHS
Tabasco_Joe is online now   Reply With Quote
f350, tow
