06-26-2020, 04:01 PM
Carrying Gas
Is it legal to carry gasoline for your tow vehicle in the back of your truck? Living in Georgia and about a gas tank drive away from Atlanta and the metro area surrounding Atlanta, I really fear getting off the interstate to fill up the truck while towing our trailer in the Atlanta area. I was just brainstorming and thought how easy it would be to get off the interstate, pull over on the on ramp, fill the truck up and keep going to our destination in the north Ga mountains. Does anyone have any thoughts on this subject?
06-26-2020, 04:27 PM
It would depend on each states laws but I would think that if you used a proper container and the space was well ventilated you would be fine.
06-26-2020, 04:44 PM
All the people who carry generators do for sure. Not sure its worth carrying enough gas though to extend your TV range.
06-26-2020, 04:51 PM
In some tunnels, it is illegal to have a propane tank.
I carry a Justrite safety can for generator gas.
https://www.justrite.com/safety-cans...fety-cans.html
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
06-26-2020, 04:57 PM
Like upflying said, tunnels would be my main concern. I’m sure there may be some limit to the amount of gasoline you can carry in portable containers but I’m not aware of it specifically. I highly recommend a metal safety can like in the picture I attached (either eagle or justrite), they are only a little more expensive, you won’t want to throw them in the garbage, and they are safer and FAR easier to pour than regular plastic cans.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
06-26-2020, 05:08 PM
Your best bet is to call this number.
(404) 631-1990 - Main Office Georgia DOT
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 230 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
06-26-2020, 05:11 PM
I've carried fuel cans (usually 5gal plastic) all over the US in the bed of my truck. So one less thing for you to worry about.......
In NM, you can carry up to 99 (maybe 105) gallons before you need a distributor bulk license.
Scott and Liz - Southern NM
06-26-2020, 05:17 PM
Tell them it is for your lawn mower , that is legal everywhere [ maybe ]
06-26-2020, 05:31 PM
I’m thinking 15 gallons would get me far enough out of the metro area where I would feel comfortable. I won’t have any tunnels to deal with so that is not a worry. That Justrite can looks pretty good, 2 or 3 of those would work well.
06-26-2020, 05:38 PM
I wanted to add to my post above about the fuel cans, Pictured below, the less expensive version of the Eagle safety can (still excellent for generator use, a little tough to fill an automobile). I keep one of these cans full of fuel in my hard tonneau covered bed and there is NO fuel smell when I open the tailgate up. It is a perfect seal.
06-26-2020, 05:41 PM
One more thing, you didn’t mention what your vehicle was but on my 2017 F-150 with the capless fuel fill you need to use an adaptor that is located near the jack to be able to fill up with some fuel cans if they don’t push far enough into the tank.
06-26-2020, 07:18 PM
Why not stop before you reach the metro Atlanta area and top off your tank? Then when once through Atlanta and you’re in an area you feel safer you can stop and top off the tank again.
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
06-26-2020, 07:31 PM
X2 or divert around the metro area
2019 F 250 6.2
2022 Columbus 329 DVC
06-27-2020, 11:09 AM
There are a couple gasoline related phone apps you can use to make sure you gas up prior to a congested area.
GasBuddy, Pilot are the two I use. Many Pilots have dump stations, too.
2019 Cherokee Wolf Pup 16BHS flipped axle
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars, SumoSprings
06-27-2020, 11:26 AM
X2! That's called "short-pitting". We do it all the time. I can see having one spare 5 gallon can, but 2 or 3? Not unless there's no other venue in the cruising range.
Just my 2¢.
2016 Salem 27RKSS
06-27-2020, 11:45 AM
Brake is on left
DOT regs allow up to 450 lbs of motor fuel to be carried in a vehicle or trailer when not used as the primary fuel source of the vehicle itself. Diesel or gas is in the 6.6 lb/ gal range. Thats a good bit of fuel. States could be different, but they arent going to pull you over for having 3 or 4 fuel cans in your truck bed. I've driven up and down the east coast with 4 fuel jugs in my bed, plus a 5 gal diesel "just in case" can. They aren't even DOT approved jugs or EPA crap cans. They actually say Not for Transport on them. Not even NJ State boys bat an eye.
All that said, reroute or short pit. The hassle of refuelling roadside is not worth it.
06-27-2020, 12:19 PM
My thought, exactly.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
06-27-2020, 01:51 PM
Los Angeles area is a whole lot bigger than Atlanta and I can drive through it no problem by getting gas before or after.
06-27-2020, 02:37 PM
Put a titian fuel tank on your truck it replaces the stock tank and can have as much as 62 gallons when full
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
06-27-2020, 02:47 PM
That is certainly a good option, but the 5 gal gas can is WAY cheaper
