Old 05-15-2020, 05:25 PM   #1
Chirping Propane Pig Tail
Only took me a few minutes to post a search on the forum for a "chirping Propane Issue". Found the issue, and it fit my situation perfectly. Now all I need to know is the easiest and best place to find/buy this replacement Pig Tail?
Sierra Destination Camper - 2017 401 FLX
dcavaiani is offline   Reply With Quote
Old 05-15-2020, 05:48 PM   #2
Flybob's Avatar
Pretty much anywhere. Check a good propane grill store or https://www.amazon.com/GASPRO-Propan...4-135149aa9081
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-15-2020, 06:00 PM   #3
Check any of the big box stores or even farm supply stores. That's where I got my last ones. Tractor Supply.
AFDON is offline   Reply With Quote
Old 05-16-2020, 08:57 AM   #4
I found my replacements at the local RV shop. I believe they were $12.99 each.
2016 T21TBHW
2017 Ram 2500 CTD CC SB 4x4
Ortep is offline   Reply With Quote
Old 05-16-2020, 09:03 AM   #5
Scoundrel
HangDiver's Avatar
Replaced mine with braided pigtails. https://www.google.com/search?q=brai...w=1245&bih=641
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 05-16-2020, 10:28 PM   #6
WFD
The male ends come in a couple different sizes. Ours developed a leak in the hose. I went to a big box store that sells most of the Camco RV stuff and bought one there that was 1/4 inch whereas my regulator thread is bigger, appears to be 3/8 so i need to find another one. I noticed Amazon has them in 3/8.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 05-17-2020, 03:04 AM   #7
DouglasReid's Avatar
Rather than buy an entire new hose you can get a 3/8" x 1/4" brass bushing and adapt that hose you have to the regulator.
Any hardware store should carry it.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 05-17-2020, 06:41 AM   #8
WFD
It's the hose that I need. After taking trailer out of storage and running through all the systems, i could hear propane hissing after turning the tank on. Turns out the hose has a crack in the rubber and that's where the hissing is coming from.
Old 05-17-2020, 08:01 PM   #9
I find that these pigtails don't last anymore. On my last trailer, in 15 years, I only replaced them once. On the current trailer, I'm lucky to get two years out of them. At first I thought it was because most of what you can find are made in China. The last pair that I bought last year were made in the US and one of those has failed already, only 11 months in service. Ed
hollywood91 is offline   Reply With Quote
propane
