Old 12-22-2021, 03:48 PM   #1
Clear Coat Peeling
Has anyone had experience with clear coat on front side molded panel peeling off. Looks like heat burned through clear coat. See photo. What can be done to stop it, fix it?
2019 Wildcat TT, WCT 312RLI
ShawneeOkie is offline   Reply With Quote
Old 12-22-2021, 03:59 PM   #2
Retired Army MSG!
lazyjj's Avatar
This is common for front caps, especially if not kept under a shed or covered. You may want to contact Forest River and see if they will assist you with warranty to be repaired. I wax mine about every other month. I have had three rigs and never had an issue with clear coat and I keep it under a RV carport here at home when not traveling.
lazyjj is offline   Reply With Quote
