03-26-2020, 03:10 PM
#21
Trip
I would put a couple of gallons of water in the black water tank to start W/ a scoop of something like Happy Camper. Prevents building a "cone" in the tank as stuff drys.
I also suggest stopping at a campsite w/ services every 3 days to refill water, dump and charge batteries.Many of the state parks are requiring you to make reservations on line. The refrigerator uses very little propane, the furnace will use propane up in several days, depending on the weather and size of your propane tanks. The electricity for the furnace fan would be the biggest power drain and concern, especially w/ 1 battery. You only want to bring the battery down to half charge w/o shortening the life of the battery.
Enjoy your trip.
#22
Originally Posted by hinkle_e
Download the Pilot/FlyingJ app. You can search and sort stations that have RV fuel lanes equipped with dump and fill right at the fuel pumps.
You don't have you don't have to use your toilet exclusively. Along the way use the state rest areas and commercial travel plazas for the call of nature. There will be ice and 20 pound tanks of propane available. Purchase a shower at
a truck stop. there will be plenty of restaurants that will deliver it to your vehicle aka the drive-thru. Hope this helps.
03-26-2020, 03:21 PM
#23
Originally Posted by debit
I think I would carry a quiet Honda 2000 inverter generator for an emergency source of power. Even using it one hour during the day could do wonders if your battery is low.
FWIW, Honda is a very good generator. With that said, if you've been following this or other RV sites, the Champion and Predator inverter generators are also getting good reviews. Predator is from Harbor Freight. Both have substantially lower prices.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
03-26-2020, 03:48 PM
#24
Not sure why you are traveling but with the way things are right now I would be staying home. Truck stops, gas stations and rest areas are going to be a crap shoot for exposure in some parts of the country that are hit the worst.
03-26-2020, 04:25 PM
#25
Why not spend a few bucks at RV Parks with power, water and sewer and your problems are solved.
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
03-26-2020, 04:50 PM
#26
Originally Posted by stevenc
MA--->UT
4'ish full travel days would prob get it done, but I'd rather not ruin myself. I'm not on a fixed schedule & 6-8hr drive times would be less taxing then 10-12hr grinds.
Do you plan to drive through Colorado on your way? If yes, be cautious of the weather on I-70 through Colorado. It can be winter throughout May in the mountains of Colorado. The chain law can go into effect during spring storms. Does your truck have 4-wheel drive?
We drive 2,100 miles from the mountains of Colorado to Boston several times a year and WITHOUT towing a trailer it takes us at least 3 - 3 1/2 days with two drivers. It's a long drive made longer if you run into a spring snow storm.
Good luck and safe travels!
SJB
2020 Rockwood 2608BS
03-26-2020, 05:07 PM
#27
Will likely go I80 which is also prone to weather closures this time of year. Fingers crossed...
2020 Rockwood Mini Lite 2506S
03-26-2020, 05:12 PM
#28
Originally Posted by bikendan
I agree. We use the propane side of our fridge all the time, especially while traveling.
I've yet to travel further than 3-5hrs at a clip with the rig, so the fridge has always maintained without operation. A lot of mixed reviews & am uncertain about running LP while driving.
03-26-2020, 05:14 PM
#29
MCTroy
Originally Posted by TheWolfPaq82
Groceries are going to be a problem. Stores are being hit pretty hard, all across the nation. I haven't seen a roll of TP in over a week now.
Our Kroger store in Troy, Ohio is stocked again - even TP. Maybe the craziness is over.
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
03-26-2020, 05:17 PM
#30
Work related. Not betting on having a ton of resources on the road, which is what prompted me to 'ask the experts' here.
Limiting exposure is certainly a priority.
03-26-2020, 05:20 PM
#31
Hit or miss this time of year. Still winter in some parts & parks may or may not be operational due to weather & plague.
I did locate a couple park possibilities in Nebraska just off the interstate.
03-26-2020, 05:21 PM
#32
Hi, Just another day in Paradise. If you don't want to dump black water, put a trash bag in your toilet and some kitty litter and you can through it in the trash can. Might want to drop down to I-70 for better weather. 85 in Missouri today....
Fred
U.S. Navy (Retired)
Lake of the Ozarks
2020 Rockwood 2104S
2020 F-150 3.5 2nd Gen
03-26-2020, 05:30 PM
#33
If you choose to use ice in the fridge put it into large zip lock bags. We do this when we set out to take out the trailer as it is in storage. It works well and is a no mess solution.
03-26-2020, 06:29 PM
#34
I agree with using the fridge on propane and I'd also use the hot water tank since you will be washing your hands a lot. When traveling like you are, I am a fan of MRE's and Mountain House freeze dried foods. Ten minutes from the time you heat or add hot water and the meal is ready. In the case of Mtn House, there's enough for tomorrow too. I take a flat of bottled water in the pickup to complement the 5 - 6 gal I put in the fresh water tank, now that hand washing more often is a must I'd probably double that amount of water in the FW tank. Safe travels and enjoy the trip.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
03-27-2020, 01:14 AM
#35
Cross country with travel trailer
Why do so many people think an rv is inoperable unless it is parked in a full service campground? Stevenc, Fill your fresh water tank, turn on your fridge and hit the road. When you want to eat pull over and make lunch. Use the toilet and even take a shower if you want. Your trailer has all the amenities for a reason, use them.
Tim and Shannon
and Sawyer The Camping Cat
2007 Chevy Silverado CC SB Z71
2013 Rockwood Ultralite 2604WS
03-27-2020, 01:22 AM
#36
A lot of rest areas are closed and I'd much rather be self-contained and have as little interaction with the public as possible during the current situation. I believe being self-contained was important to the OP for just that reason. Two 20 lb tanks should be more than enough propane to make it cross country. No need for ice. The fridge will stay cold even if the propane is turned off while driving since OP is planning short days.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
03-27-2020, 01:24 AM
#37
^^^ This. This is exactly what I would do.
03-27-2020, 01:26 AM
#38
A lot of parks are closed, especially for transients.
03-27-2020, 11:58 AM
#39
Pretty soon, if you put everything suggested in that thing, you wont' have any room to walk from one end to the other.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-27-2020, 01:59 PM
#40
Right?!
I should have known better than to leave such a vague initial post.
