12-21-2017, 01:31 PM
Curious Question
A group of friends and I were talking all things RV and struck upon this curiosity about using an invertor while boondocking or dry camping. When there is no shore power or generator can one temporarily plug the shore power cable of their RV into an adequately sized invertor to run the microwave for a minute or two? Will this cause a problem for the convertor? Anyone try this?
2015 Flagstaff 8528RKWS
2013 Ford F250 Super Duty
12-21-2017, 01:45 PM
Sure
The bigger the battery bank and inverter you can run anything!
2000/4000 peakwatt inverter properly wired should run a microwave. Two batteries discharged in about an hour.
Recently new!
Yes you can....BUT!!!!!!! You will need a large enough inverter, a battery bank big enough to handle the discharge rate. That said, assume your microwave is 1,000 watts. You will need a minimum discharge rate of around 150 amps while it is running. (Inverters are not 100% efficient) Most single battery banks will be destroyed after several minutes at this rate! Sometimes with disastrous results!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
12-21-2017, 01:47 PM
Forgot to mention disconnecting the converter. Flip the breaker.
12-21-2017, 01:50 PM
Always Learning
That's actually how we run our camper when boondocking. I only have a 1,000W inverter so no microwave, Instant Pot, or A/C. Even the A/C fan is iffy depending on what else is running at the moment (it worked great for 10-15 minutes and then tripped the inverter's overload- my guess is our mini-fridge's compressor kicked on).
Inside the camper, I turn off all of the breakers except for the main house one. Then I'll manage the load by controlling which breakers I turn on. I have 2 breakers that control a vast majority of outlets in the rig.
I have a 50amp to 15amp adapter that plugs right into the camper's shore power inlet. Then I have a 50' x 10 or 12 gauge heavy duty extension cord that I run to the GFCI on the inverter.
Battery-wise, I have four 100amp-hour lithium drop-in batteries from Battle Born. The way they have their batteries setup is that you're able to use all 100amps, so it's like having close to a 800amp lead/AGM battery bank (where you shouldn't go under 50% state of charge).
If I had a bigger inverter, I wouldn't mind running the applicances that I can't now.
Insert witty title here
It will work in theory but I would advise against it. Microwaves use ALOT of power and will likely drain your batteries VERY rapidly. Use the propane oven and stove to heat things up while boondocking.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
12-21-2017, 01:51 PM
Always Learning
This is an absolute must. Otherwise, you'll send your batteries into a quick death spiral by trying to self-charge them via the inverter.
12-21-2017, 01:57 PM
I had a 1500 watt inverter in the truck I was driving for a living. I found that with 4 12v batteries it wouldn't run the microwave efficiently without the motor running to add more charge to the batteries. Best example is popping microwave popcorn, it wouldn't pop all the corn on battery power alone, with the motor running it worked normally. I only had 3 ft #4 cables from the batteries to the inverter.
We love camping in our Shockwave!
2016 t28FQDX Shockwave,
New Provider tires 10/31/18 ,
2021 Chev LT 3500
2020 Polaris RZR 900 Fox Edition
12-21-2017, 02:44 PM
Wrench Turnin Fool
#4 is too small for the load, you get voltage drop which increases the current draw which drops the voltage...
Not all who wander are lost...
But I usually am
2001 Coleman SantaFe pop up
Excited new owner of 2018 Arctic Wolf 315TBH8
Towing with a 2005 F-250 5.4 GASSER
12-21-2017, 02:54 PM
It's so much easier to just get a 2000w inverter generator.
You can run the microwave and recharge the batteries.
12-21-2017, 03:32 PM
Always Learning
If you’re already investing in the battery bank, I wouldn’t say “easier”. Unless you have a remote start for the generator, you have to go outside- fire it up, microwave your stuff, go back outside and shut it down.
It’s a whole lot “easier” to just start the microwave.
12-21-2017, 04:26 PM
Boon docking/ Microwave is an oxymoron.
Chummy V
2014 Forester 2501TS
Ford E-450
12-21-2017, 08:29 PM
You are right but DW demands AC even when 70 outside....I have to do that anyway :-)
12-21-2017, 10:46 PM
With due respect to "What True Boondocking Is" here are my observations;
Rigs big enough to have battery banks large enough for running a microwave typically have an inverter big enough to cover this,and an on board genny so its a non-issue.
For smaller rigs, like a TT with 1 or 2 batteries, the microwave is a huge draw. I considered such an upgrade, but the microwave would kill my batteries in minutes. I installed a 300 watt inverter with a dedicated outlet. It runs the television, charges gadgets that need 120v, and laptops. For cooking, propane is your friend. If we just must have the microwave, or AC, like Bikendan said-it is generator time.
12-22-2017, 02:40 AM
Are you sure about that? #4 is pretty hefty wire.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
12-22-2017, 03:56 AM
Good for 100 amps AC in most cases.
12-22-2017, 07:13 AM
If you are going to attempt this, keep your inverter as close to the batteries as possible to minimize DC voltage drop across the wire.
12-22-2017, 07:44 AM
I solved this problem by removing the microwave oven from my R-Pod, and gained a lot of storage space as a side benefit.
12-22-2017, 08:48 AM
If you're running true 4 AWG OFC wire, then it should handle 150 amps or better if it's only a 4-7ft run. You want to locate the inverter as close to the battery bank as possible since it takes larger wire to carry lower voltage for a given amperage.
12-22-2017, 08:54 AM
Recently new!
Problem with AC vs. DC, is best summed up...Line loss. All wiring has resistance to electron flow per foot.
With AC circuits, you will have about the same line loss in voltage per foot as a DC circuit. However, with AC, you are usually talking 120 volts. If you get the spec's on wire, you can calculate line loss in volts per given distance. So, if you are talking a loss of 4 volts at say, 5 feet under load (in amps), then your loss is very minimal at 120volts, as it drops from 120v to 116v.
Drop that 4 volt loss to 12 volts dc, then you are talking significant voltage drop. 12v -4v =8v. Your device will draw even more current trying to make up for the voltage drop, exacerbating the problem.
To figure out what wire size (gauge) you need, you really need to include the voltage drop of the distance you are going when setting up DC systems. These can be found here: Voltage Drop Calculator
2001 Ford F-250 7.3
