Old 04-30-2020, 10:17 PM   #21
You'll never completely clear the water filter of the pink stuff unless you unscrew it and dump it out. I fixed the problem by taking the factory supplied filter, with it's overpriced replacement filter cartridge, out and trashing it. I use an external hose filter now.
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
Oafdawg is offline   Reply With Quote
Old 04-30-2020, 10:24 PM   #22
Filter
I use a large plastic bowl on top of a towel.
Tundra 2014 is offline   Reply With Quote
Old 04-30-2020, 10:38 PM   #23
A few years ago, I purchased a metal disk insert for the filter cartridge that is put in before winterizing. This prevents antifreeze from filling the cartridge.
When I winterize, I blow out the system with compressed air using the city water attach point. This will remove almost all of the water from the cartridge making it easy to remove. I do, however, need to remove the cartridge and change the filter a number of times each year because I use two different types of filters. For these exchanges, I put a towel under the cartridge and use a small diameter plastic tube to make a siphon to drain out the water from the filter cartridge once I unscrew it. There's very little spillage when doing this.
Phil
pmsherman is offline   Reply With Quote
Old 05-01-2020, 09:59 AM   #24
Wolverine 1945's Avatar
Phil
As did I, dammed if I can remember what it was called ???
Wolverine 1945 is offline   Reply With Quote
Old 05-01-2020, 12:22 PM   #25
My filter cartridge was oriented vertically. The plumbing came and left at the top, and the clear plastic canister (filter holder/housing) hung from that.
All I had to do was depressurize the system, put an old towel under the canister to catch a few drips, and remove the canister and carefully take it outside and dump.
I winterize with air, so, for me, this process always happened AFTER blowing the lines dry, which eliminated any "gravity feed" from water lines. But, since the filter is usually higher than most of the plumbing, there should not be a lot of water in Pex lines that can drain back through the filter mount. A decent old bath towel should absorb that much water.
With dry Pex lines to and from the filter (air does NOT blow the filter housing dry) I seldom "spilled a drop" when removing the canister.
That's one guy's experience...may not be representative. Perhaps overthinking this?
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito
jimmoore13 is offline   Reply With Quote
Old 05-01-2020, 12:45 PM   #26
Just as confused as you
Scrapper's Avatar
I agree. With the weight of air considerably lighter than water, once the air pushes the water from the top 1, maybe 2 inches of the canister it will take the path of least resistance. Most likely you will have a housing about 3/4 full.
Richard & Jill
Old 05-01-2020, 02:37 PM   #27
dbledan's Avatar
I winterize via compressed air. This was my experience as my filter had a top input and top output. I never got more than an inch or two out of it with the fiter removed. Perhaps different configurations do better or better if you left the filter in.
I grew tired of it and removed the filter using an inline one instead, though a bypass would be good as well.
dbledan is offline   Reply With Quote
Old 05-15-2020, 08:20 AM   #28
Water bottle
Originally Posted by 45RPM View Post
Since a filter is unnecessary when winterizing, someone should make a SMALLER cartridge to replace the big one so that we're not wasting antifreeze when winterizing!
I put a bottle of water, or something similar in the housing to take up the space of the missing filter. Anything will do.
Threex14 is offline   Reply With Quote
drain, water, water filter, winter, winterizing
