GS, with an adapter, you can plug your 30 amp cord into a standard household socket. Doing this, you may be able to run JUST the A/C As long as you do not have anything else on. Typically the standard household outlet is between 15 - 20 amps. So if you are wanting to run more than just the A/C, it may be best to have a 30 amp socket and breaker installed?
Retired Army CW4 - "Waterborne"
2005 Chevy 2500 crew cab with Duramax/Allison
2014 Lacrosse 327RES
Days camped 2014 - 0, 2015 - 24
