Old 06-22-2021, 02:19 PM   #1
Do I need chocks on either side of both tires?
N00b here. About to pickup "Kitty" (as in Hello Kitty, don't ask) this weekend and furiously shopping Amazon.
My TT is a single axle, which means the X chock won't work and I'll need to get chocks on the ground. Looking at Maxxhaul rubber chock, comes in a 2-pack on Amazon. I have seen YouTubers using chocks for both front and rear of the tires, but only one side in the videos I've seen. Does the other side need chocks as well?
ciditad is offline   Reply With Quote
Old 06-22-2021, 02:22 PM   #2
RV There Yet?
IsleDog's Avatar
I have owned two single axle trailers and we always use chocks front and back on each tire. it does help with the stability a little bit.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 06-22-2021, 02:33 PM   #3
I have done in the past when I had single axle trailers is to put chocks behind both tires, the back up slightly so there is some pressure on them, hold the brake and put the other set in front of the tire, then let off the brake. This holds it tighter to prevent some movement.
This also helps with leveling and stability
https://www.amazon.com/EAZ-LIFT-Leve...omotive&sr=1-2
2021 Coachman Northern Spirit 2963BH
2017 Dodge Ram 1500 Laramie
Old:
2019 Rockwood ROO 233S, 1998 Dutchman 747SL, 1988 Jayco 1006, 2001 Skyline Nomad 3710BH,1997 Coachman Catalina lite 249 QB, 2001 Palomino Mustang SC
Wisconsin-1 is offline   Reply With Quote
Old 06-22-2021, 02:51 PM   #4
Boss Ox & Drovergirl
oxcamper's Avatar
Chocks on both sides, and in front and rear of the tires. For your single axle, you'd need 2 sets (4 chocks)
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 06-22-2021, 03:15 PM   #5
Agreed.
Without them in front and behind both tires, you do have a chance that one wheel could move because of gravity, and cause the trailer to spin (tongue left or tongue right) if you weren't on level ground. I've even once made the mistake of not chocking the front/back of both tires on my boat, and unhooked on what I thought was fairly level ground. Once there was no more pressure on the ball hitch / coupler, the trailer moved enough to put a nice dent and scratch in my trucks bumper. Not happy with myself and my cheapness / laziness to just put down all 4 wheel chocks.
Me, the wife, & 2 daughters (12 & 7yrs old)
2019 Palomino Puma QBSS
2015 Silverado LTZ / Z71 w/ many upgrades
GXPWeasel1 is offline   Reply With Quote
Old 06-22-2021, 03:25 PM   #6
bikendan's Avatar
Yep, this is very popular in the Popup community.
Old 06-22-2021, 04:29 PM   #7
asr524's Avatar
Been here before...I had leveling blocks on one side of our old single axle. I only chocked the other side. I just unhooked from the truck and didnt have stabilizers out and the wife stepped up into the RV. That caused the RV to pivot about the chocked wheel and roll off the leveling blocks.
Kind of scary having the tongue swing toward you out of no where.
2021 Wolfpack 315Pack12
2014 Ford F350 6.7L Diesel
2019 Indian Chieftain Dark Horse
asr524 is offline   Reply With Quote
Old 06-22-2021, 07:54 PM   #8
Chocks, chocks and more chocks, you cant have enough chocks, because if for some reason it moves, or you get distracted while unhooking the trailer you'll be glad you had extra chocks, LOL..
rowdy boys 3 is offline   Reply With Quote
Old 06-22-2021, 08:56 PM   #9
Trailer Park Supervisor
NJKris's Avatar
Chocks are cheap at Harbor Freight.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 06-23-2021, 05:18 AM   #10
I think so. Chock one side only, and the trailer could pivot on you. I use the heavy rubber chocks, and do the same axle on both sides of the trailer.
2021 Freedom Express 20SE (formerly 204RD)
2022 F150, Power Boost, 4x4 SuperCrew. 6.5' Box, 7.2 Kw Generator
Atlee is offline   Reply With Quote
Old 06-23-2021, 09:26 AM   #11
I only use them on the downhill side; guess I'm lazy.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 06-23-2021, 11:08 AM   #12
oxcamper's Avatar
Well I guess one could say:
"Chock one up for using chocks!"
Old 06-23-2021, 11:33 AM   #13
I second the harbor freight rubber chocks. They do emit quite an odor for a while, I think it is how HF gets their distinctive smell.
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is offline   Reply With Quote
Old 06-23-2021, 11:41 AM   #14
NJKris's Avatar
But it's that nice new tire smell!
Old 06-23-2021, 07:16 PM   #15
Dangerous!
That would be pretty dangerous.
The downhill side tire is unlikely to roll uphill.
The uphill side tire is very likely to roll uphill--and it's a gamble whether it will roll forward or backward when it does.
As Clint Eastwood said in one of the Dirty Harry films, "Do you feel lucky, ...? Well, do you?"
Larry
Larry-NC is offline   Reply With Quote
Old 06-23-2021, 07:24 PM   #16
Originally Posted by Larry-NC View Post
That would be pretty dangerous......The downhill side tire is unlikely to roll uphill......The uphill side tire is very likely to roll uphill......"
Huh, how would the trailer roll uphill? Let me 'splain myself more clearly. Not talking about side to side. The downhill side would be the direction the trailer would roll, fore or aft, if no chocks were used.
Old 06-23-2021, 08:21 PM   #17
Confusing me
You're confusing me. Let's try this again. We will consider four cases.
Case 1: Tongue is pointing uphill
Suppose you put a chock under only the left wheel. The right wheel will roll downhill, dragging the jack in a 90-degree arc, starting across the face of the hill and ending tangent to a line going down the hill.
Case 2: Tongue is pointing to the right, across the hill face
Suppose you put chocks under only the right (downhill) wheel. The left (uphill) wheel is in a metastable position. A little nudge, either forward or backward will cause the trailer to switch directions, spinning 180 degrees, so the uphill wheel becomes the downhill wheel, while the chocked wheel stays in place. The jack describes a semicircular arc.
Another possible scenario starts the same, but as the trailer goes through the 90-degree point, the chocked tire is now cross-wise to the chocks and the trailer goes merrily downhill plowing a straight line down the hill with the jack. This could cause some serious damage.
Case 3: Tongue is pointing downhill
Suppose you put a chock under only the left wheel. The right wheel will roll downhill, dragging the jack in a 90-degree arc, starting across the face of the hill and ending up tangent to a line going up the hill.
Case 4: Tongue is pointing to the left, across the hill face
Mirror image of case 2
I don't see any situation where there's stability on a hill without chocking both tires of a single-axle trailer front and back.
Larry
Old 06-23-2021, 08:28 PM   #18
But being Harbor Freight, I bet the tire is a China Bomb!
Old 06-23-2021, 08:30 PM   #19
NJKris's Avatar
But when they're on a wheelbarrow, who cares when they blow!
Old 06-24-2021, 06:04 AM   #20
asr524's Avatar
I think he meant for your case 1 where the tongue is facing uphill then you use a chock behind the left and right wheel. I dont think he is just using a single chock as your scenario described.
Same would be true for case 3 but this time the chocks are in front of the wheels.
chocks, tire, tires
