Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 03-01-2021, 08:26 PM   #41
Yes. Doing it 50 years. Full charge in a couple hours.
I have to question negatives. They must not tow trailers.
IDguy is offline   Reply With Quote
Old 03-01-2021, 08:30 PM   #42
Mandog's Avatar
This is what I have done to several friends vehicles. I run 2 - #2 cables to the rear bumper area of the truck. Install a quick connect. Then from the Trailer I install the same from the batteries. Up close to the tow vehicles battery I installed the 100 amp circuit breaker. It can be used as a switch also to disable it until it’s needed. It’s always worked well for them. I need tondo it to my set up as well. Hopefully I’ll get time. A little attention to detail and it will be trouble free and work great for years to come. My 2005 2500 6.0 gas Silverado has the tow and plow package which gives it the 200 amp alternator. No issues at all with output. One word of caution. If you don’t have a battery buddy installed to cut the voltage off at 11.5 volts you won’t be able to start your tow vehicle. The ignition ready circuit breaker can help as well by not letting current flow until the ignition is turned on. The goal is to charge and supply these new 12v refrigerators and keep battery’s topped off while traveling.....4 hour trips when running these appliances can be very hard on batteries....... This was kinda easy and the wire is the most expensive. I’m a welder/fabricator and am very mechanically inclined but really isn’t that bad...Good luck...
Bill Burke
Firefighter, NREMT
2020 Forest River Vibe VBT32BH
05 Chevy 2500HD 4x4 6.0
Wife W/3 rescue dogs & 12-16 chickens
Mandog is offline   Reply With Quote
Old 03-01-2021, 09:36 PM   #43
Our Ram 2500 diesel has two 170A batteries and a 220A alternator. We routinely dry camp for the night on long trips and leave the truck connected to the fifth wheel. When going south of I-10 to snowbird, we have the furnace and tank heaters running all night and the refrigerator on propane. We have been down to single digit temps and never had any difficulty starting the truck the next morning. The truck provides sufficient power and the alternator fully recharges the trailer during the following day's drive. A winter day's drive on I-25 and I-10 is generally 6-8 hours, unless it starts snowing or the wind is blowing 50 mph! Then we hole up in a NM state park with electric hookups.
fanrgs is offline   Reply With Quote
Old 03-01-2021, 10:14 PM   #44
Herk7769's Avatar
There are DC to DC chargers that increase charging rates.
Which comes with its own set of problems ...
HAM CALLSIGN - KC3FFW
Old 03-01-2021, 11:24 PM   #45
How is that a problem?
2019 F150 HDPP 4X4 3.5. 2500lb payload.
2018 Rockwood 2506
Half Ton Heavy is offline   Reply With Quote
Old 03-02-2021, 12:05 AM   #46
I have a 15 ram 1500 with tow package. It charges or TT while towing. It will drain your TV battery if you leave it them connected and TV not running.
We went to the Tetons from Mi last spring and camped with no generator or hook up. I would hook them together with the truck running to charge the TT and it worked great.
Donniesoup is offline   Reply With Quote
Old 03-02-2021, 09:14 AM   #47
Yes it does charge your battery
Goatspower is offline   Reply With Quote
Old 03-02-2021, 09:29 AM   #48
I simply was pointing out to the OP who was asking questions about the vehicle charging the R/V battery that there are options besides just the factory supplied wire/charge.
Since you must believe my advice is a can of worms, maybe you'd like to expound on why you think so.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=19
Old 03-02-2021, 10:16 AM   #49
I just got a generator instead
I have seen YouTube videos that show how to install a DC to DC charger. Requires heavy gauge wire, circuit breakers and heavy duty connections to the TT battery. and May require a bigger alternator? That's the only way I know to get good charging. I did not want to fool with that so I bought a generator.
In my experience the TV will not charge the battery enough for overnight use for more than one day. Unless you run it for several/many? hours. I have 2- 6 volts in my TT and the standard 7 pin plug.
MontanaWill is offline   Reply With Quote
Old 03-02-2021, 10:38 AM   #50
JCR
Originally Posted by pedwards2932 View Post
Does the battery voltage between TT and TV battery level off to the same voltage when the TT is plugged in? My guess would be no. The way an alternator works AFAIK is it has a sensor wire from the battery to the regulator. The regulator applies more or less current to the fields to regulate how much charge is put in the battery. If the alternator doesn't read the TT battery voltage then it is controlled by the TV battery. Does that seem correct?
I would think that once the TV is connected to TT all batteries are now in parallel circuit.Therefore the voltage the alternator regulator recognizes will be consistent across all batteries in the connected circuit. Unless there is some electrical isolator between the TV and the TT.??
JCR is offline   Reply With Quote
Old 03-02-2021, 11:27 AM   #51
Herk7769's Avatar
Perhaps I misspoke. I was under the impression that DC to DC chargers have limited charging stages that could result in overcharging issues. If that is not the case, my apologies.
https://www.victronenergy.com/upload...50-400W-EN.pdf
I see that this unit does have 3 stage charging and thus my concern would not an issue.
Old 03-02-2021, 11:52 AM   #52
JCR
My TV connections has pin marked Bat.. Therefore its hot all the time and is directly connected to the vehicles staring battery. When the alternator regulator senses low voltage it cranks it up so all batteries will receive a charge including the TT. How much depends on the regulator and alternator outputs.
Old 03-02-2021, 12:52 PM   #53
Installers for DC to DC Charger
I have a 2016 Ford F 350 & Rockwood 8332 with 2 - 6 volt AGM golf cart batteries. I'm looking for an installer to add a 40 amp Renogy DC to DC charger to truck activated through the dash toogle switches to suppliment charging to the camper batteries. We are in Central Florida & not really getting anywhere with Renogy support. Any assistance or direction would be greatly appreciated!
knoxtriguy is offline   Reply With Quote
Old 03-03-2021, 07:52 AM   #54
As far as I know, yes you are right. If there is no current flowing in the wire, the voltage will be the same. As the current increase, the drop in the wire increases. For non-car voltage regulation (ie: electronics) you use a small conductor where there is no current for the sense circuitry. That way the regulator will increase the voltage at the source to control the voltage at the destination (the battery).
Sadly when towing a trailer, there is no sense wire between the trailer battery and the regulator, so trailer battery is at a somewhat lower voltage. The good news is that if there is voltage drop in the wire, that's because current is going in the trailer and that's what you want!
jf
jflarin is offline   Reply With Quote
Old 03-03-2021, 09:55 AM   #55
Renogy dc to dc My stupid question
STUPID Question
i have heavy wiring to the 7 pin to charge the batt on my TT but i had a problem traveling in the south last yr it couldent keep up the charge on my 2 - 12V batt i have 300 watts solar all renogy
it was so hot that we parked in the shade when ever we could ...
thus no solor charge i had to run the gen a lot so my stupid question is ...
im looking at the renogy 20 amp i know every body is using the 40 amp ..
but do to the fact.
i like to spend money on old black betty so funds are tight..
i am all so swapping out the 2-12V batt's for 2- 6V batt's
2000 dodge ram 3500 5.9 cummins customized for my puppies
2014 roockwood 2608ws customized
BOO-BOO-IS-IN-CAMP is offline   Reply With Quote
Old 03-03-2021, 10:59 AM   #56
Camping the Natural State
My truck has a high capacity alternator and does a pretty good job topping off the camper battery on 100+ miles trips. There is a relay under the hood that keeps the camper from pulling power off the truck battery with the ignition off.
2021 Rockwood Ultra Lite 2614 BS
ARhappycamper is offline   Reply With Quote
Old 03-03-2021, 01:05 PM   #57
Solar Panels were mentioned...
If there is power coming from the TV and Solar... who charges the TT?
(I know the first answer... "It Depends").
BunnyCamper is offline   Reply With Quote
Old 03-03-2021, 05:22 PM   #58
Whoever produces the higher voltage. So yes, it depends.
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
mac1_131 is offline   Reply With Quote
Old 03-04-2021, 08:34 AM   #59
DC/DC Renogy 20 amp charger/LIFEPO4 12v drop in
I upgraded my 1706 pop up from a 65 ah lead acid to a 100ah Li drop in and left it mounted on the tongue in an ABS 24 battery box. My tow vehicle had a 160 amp alternator with a 4 pin trailer plug. I converted that when I bought my camper to a 7 pin for the camper brake system. That kit included a 8 gauge wire going from the service battery/alternator to the aux power pin on the 7 way which I used to directly input power to the Renogy 20 amp DC/DC charger. The 8 gauge wire was the minimum size for the 20 amp charger for 15 feet per the Renogy install wire chart. The 40 and 60 amp chargers require larger gauge wire.
The main reason for installing the DC/DC 20 amp charger was to limit not increase my charging rate from my service battery to the LIFEPO4 house to 20 amps to protect my wiring and alternator. Lithium batteries differ from lead acid in that their internal resistance is very low and can accept very high charge rates, up to 100 amps for mine, frying wires and alternators when being charged from a low to high state of charge. With this set up my charging amperage when towing at 2500 RPM to a low SOC house Lithium is kept below 18amps.
For towing in cold weather I installed a DC 12V Fahrenheit Digital Temperature Controller 10A Relay with Sensor and switch that automatically stops alternator charging to my Lithium below 35F battery case temperature. I also wrapped my Li battery in a 10amp 12v DC tankless water heater heater that provides 6 amps of heat heat below 40 F thermostatically. This increases my ambient charge temperature range. Nobody makes a Lithium 12v battery heater, just 120v and they are not recommended for Lithium’s. Cold weather Lithium’s are now on the market with internal battery heaters but are $300 more than the non heated ones. The 12v heater is $40 and only draws 6 amps and will not melt a ABS plastic battery box and was given the okay by my Lithium battery manufacturer.
I also switched out my WFCO 30amp power center for a Progressive Dynamics 35amp Power Center with a Lithium switch for 120v Lithium charging. I sold the WFCO on EBay for $80.
This was a retired pilot Covid project with time on his hands scheduled for a vaccine shot next week which was kept under $700 who is ready to hit the road.
RVasylum is offline   Reply With Quote
battery, tow vehicle, trailer
