10-31-2022, 07:11 AM
Don't skip your pre-trip inspections!
Last weekend on the way out to our campsite, a boondocking spot through Harvest Host, I heard a strange sound coming from the suspension just a mile or two from our campsite. Once we got parked, I checked the suspension and found this:
We were about 200 miles from home on a Saturday late afternoon. I called around to every RV dealer in about a 75 mile radius, and none of them carried ANY suspension parts. They all said they replace the entire suspension system under warranty generally, so don't carry any suspension parts. I couldn't believe none of them carried ANY shackles.
Luckily, a local Tractor Supply had 2 1/2" shackles and bolts in stock. The shackles on my trailer were 2 1/4," but that was close enough to get me back on the road and back home. Though, I'll be looking for some heavy duty shackles to replace the cheap stock ones.
What a pain to replace at the campsite...
Thankfully this wasn't much worse. I shudder to think of what would have happened if it would have gone while on the interstate. We had some REAL rough roads along the way which certainly contributed to the damage... But I should have been checking the suspension more closely, as I'm sure there were warning signs earlier. I do pre-trip inspections every time, but I think I may have gotten a bit lax on checking some parts real closely.
So just a reminder to everyone, do your pre-trip inspections carefully, and don't skimp out on checking what needs to be checked!
10-31-2022, 08:00 AM
Wow, that's a lot of wear! Glad you caught that when you did. I have never seen shackles wear like that. Is that on the 2021 Grey Wolf 22MKSE in your profile?
2018 Flagstaff Super Lite 29RKWS
1999 Ford F-350 Crew cab 7.3 diesel SRW 4x4
10-31-2022, 08:07 AM
The expression is ducked a bad one.
We were not so lucky. Our bolt broke. Cost $7500 to repair.
Fortunately we discovered the issue before the fifth wheel did something terrible.
If it were me I would replace all bolts shackles etc. wet bolts.
In China quality is on no one’s mind. Crap steel.
10-31-2022, 09:01 AM
Yikes! Glad you caught it. Time to not just replace but upgrade all of them.
2019 Freedom Express 248RBS
2012 F150 Supercrew 4x4
10-31-2022, 09:55 AM
It sure surprised the hell out of me. Yes, it's on the 2021 22MKSE. I've towed it about 20,000 miles, including doing a lot of bumping around on dirt roads boondocking. I think this added to the premature wear... Though I still would not have expected this.
10-31-2022, 09:57 AM
I plan to replace all of them with upgraded parts that have grease fittings during the offseason. I'm leaning toward the MORyde set I think.
10-31-2022, 10:22 AM
I’ve also been there. I had made it to a campground and noticed the trailer was leaning on a perfectly level concrete site pad. I climbed under and found this:
The nearby service center where I’d had a couple of big jobs done told me they could get me in in 3 months.
I ordered a spring shackle/wet bolt kit
sent to my home 35 miles away and my brother and his son-in-law came and helped me make the swap.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135; 12/'23 Booked for 2023 = 14
10-31-2022, 11:15 AM
Attachment 281121
Attachment 281122
Attachment 281123
Attachment 281124
That actually makes me feel better. I figured if it would have snapped that it would have been much worse, at any speed. Still happy I found it when I did though.
So you replaced the leaf springs too?
10-31-2022, 11:29 AM
No, I didn’t replace leaf springs — only the parts in the kit shown in my 2nd pic.
10-31-2022, 11:55 AM
That's the same kit I'm looking at doing for mine. How do you like yours? Any problems with it?
10-31-2022, 01:18 PM
I’m happy with the kit. It’s out of sight, out of mind. There are instructions on how to orient the wet bolts and we got up & down right BUT we didn’t point their grease fittings to the inside. Now I have to remove wheels to grease wet bolts correctly. I wasn’t the one under the trailer and didn’t think to give instructions.
10-31-2022, 02:09 PM
Good to know!
Have you tried using a 90 degree adapter on your grease gun, like this, to avoid taking the wheels off?
https://www.amazon.com/Slippery-Pete...-3-spons&psc=1
10-31-2022, 03:13 PM
Now that you mention it, I DO have a 90 deg. adapter.
11-01-2022, 12:27 PM
Following
2016 FR Wildcat 327re 5th wheel
2013 Ford F350SD
11-02-2022, 07:19 AM
Retired Old Guy
Or replace the fittings with 90° ones, obviously you will have to find out what size thread they are. Auto parts stores should have them if you bring one of yours to match the size.
Check this out! https://a.co/d/0lxIxbZ
11-03-2022, 10:02 AM
Gotta love Amazon!
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
11-03-2022, 10:12 AM
I’m familiar with 90 and 45 degree fittings but it’s much easier for me to use my 90 degree grease gun adapter than to get the correct 90 degree grease fittings and to install them. Thanks anyway.
11-03-2022, 10:46 AM
On the way from Abilene to Boerne in August of 2021 cracked a leaf spring on door side of the axles. Called Bobby's out of Kerrville and he and his son came out to the campground and looked it over. He advised us to change both sets of leafs and all shackle parts. Did it right in the campground and did good work. Nine years and 100k on the rig so I think we got good use of the parts. Repairs were not cheap but it's worth it to have a quality job. He discounted for a cash deal.
Dave
2014 Sandpiper 35ROK
2004 Volvo VNL64T 630 left tandem
D-12 435 HP 740 CU
Western Golf and Country Cart (custom body, EZ-GO frame)
Arguing with some people is like trying to smell the color 9
11-07-2022, 07:08 PM
I picked up my new 2022 salem crusie lite 171rbxl and ordered a wet bolt shackle kit and replaced the plastic bushings which had all ready started to wear out with very few miles on them.
11-07-2022, 07:42 PM
Looking at your situation, something appears to be bent! Or maybe miss aligned,in any event you got home. I'm surprised its worn out so fast!
Snoopy
