I put French Doors in a park model RV once. I took the sliding door out and framed in the french doors and it looked really nice. You can buy no-mull doors where you can open both doors or you center mull doors where just one panel opens. I used crown molding around the frame to account for the difference in thickness between the wall and door frame.
If your sliding door is standard 6-8 height you will have plenty of options, however if you have a short door you'll likely have to have something special made, or enlarge the rough opening to fit a standard door.
Gotta go campin!
