Old 07-17-2022, 05:29 PM   #1
drawer alignment off? Help
Hi all,
I have a 2019 Mini Lite 2104S. The drawer under the sink was wobbling all over. Pulled out drawer and found the wood that the drawer was mounted to wiggled all over. RV repair shop added a wooden block to stabilize the wood
that the glides were attached too, from wobbling left and right. worked fine for a few open and closes.
However not long after, the right side of the drawer pulls out farther that the left side.
Anyone experience that before and how did you fix it? Do I need all new glides?
thanks
Duckfan is offline   Reply With Quote
Old 07-17-2022, 06:59 PM   #2
The glides should click in when the drawer is fully closed. You can try opening drawer and checking to see if one side is pulling out too far. Grip the moving glide on the side and hold it out as you close the drawer to see if it will latch into place. You can remove and re-install the drawer to be sure is in the right track.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is offline   Reply With Quote
Old 07-19-2022, 05:24 PM   #3
Sorry for late response. Thanks you for the idea. Still not working right. I'll probably just replace the glides, and that will hopefully do it.
Thank you again for your helpful suggestion! take care
alignment
