Old 08-05-2021, 08:59 AM   #1
071567's Avatar
Dresser drawers
I know it's been talked about on the form ,but can't remember where I saw it at. My dresser drawers will not stay closed while traveling. What's the best way to keep them closed.
071567 is offline   Reply With Quote
Old 08-05-2021, 10:00 AM   #2
Always Learning
This is what the manufacturers used on my 2 trailers and they seem to mostly work:
Hardware House 64-4567 Contractor Pack Roller Catch, Brown, 10-Pack https://smile.amazon.com/dp/B002BY9J...KG7CN7AEAJA8KE
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 08-05-2021, 10:40 AM   #3
If you have the drawers loaded heavy you might need to put 4 of those catches on to get the job done. We have a drawer in our current RV that we finally gave up and put a gate hook on because it has all of the pots and pans in it and no standard drawer catch would keep it closed while driving.
2021 Coachmen Freedom Express 246RKS
2020 Ford Ranger
DougW is online now   Reply With Quote
Old 08-05-2021, 04:07 PM   #4
071567's Avatar
That's what is on it now, but it won't stay closed even if it's empty. Thinking about those magnetic closers
Old 08-12-2021, 01:27 PM   #5
071567's Avatar
Thinking about trying heavy duty Velcro
Old 09-03-2021, 06:40 AM   #6
071567's Avatar
Do these types of closers get weak over time.
Old 09-03-2021, 06:56 AM   #7
NMWildcat's Avatar
Do a little more research on types of drawer latches. I replace all the cheap, weak factory latches when we buy a new RV. You can buy latches of different pull strengths. I use 15lb to 60lb pull strength depending on the drawer. There are many types and may install differently depending on the drawer or cabinet.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-03-2021, 01:56 PM   #8
071567's Avatar
Where is the best place to get them from
Old 09-03-2021, 03:03 PM   #9
Trailer Park Supervisor
NJKris's Avatar
I was mad one of my drawers broke from flying open in transit. Forest River guy showed me the mechanism that's supposed to keep them closed I never even knew existed. At the end of the rails closest to drawer face, there is a mechanism with a spring loaded 'nub' that makes friction during initial drawer movement. Apparently there is a screw adjusting tension on this nub. On one side of this mechanism is a screw for increasing/decreasing tension. Probably on underside where you can't see it. NOBODY TELLS YOU THIS.
I just went out and fooled with mine. Each mechanism with the spring loaded nub is installed so one side is adjustment screw side up, screw is facing down on opposite side.
NJKris is offline   Reply With Quote
Old 09-03-2021, 03:18 PM   #10
Mr. Dan's Avatar
I used magnetic drawer latches like these. https://www.lowes.com/pd/Brainerd-Br...Catch/50426698
One didn't hold the silverware drawer very well so I installed 2 sets on that drawer and the one below it. No issues since.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 84; Booked = 28
Old 09-03-2021, 04:02 PM   #11
NMWildcat's Avatar
Any hardware store has them. Just do a google search on drawer and cabinet catch or latch and you will find all kinds
Old 09-03-2021, 08:13 PM   #12
071567's Avatar
I found some on Amazon. Magnetic closers 25lbs
Old 09-03-2021, 08:15 PM   #13
071567's Avatar
Thanks I'll look for the adjustment screws.
