05-05-2020, 04:04 PM
Newbie
Dropped my Trailer
About the time you think you have things figured out, they go wrong in a hurry. Hitched my 2104S up to pull it back to the storage lot like a hundred times before. Latched it down and hooked up chains and cables and took off. Made it about 2 1/2 miles and crossed a bridge over an interstate doing about 30 mph and the trailer came unhooked. I was dumbfounded. Coupler latch was down with the safety pin still installed. Ball mount and hitch pin still hooked up. Safety chains kept this from being a total disaster.
I was able to get it jacked up and rehooked back up with very little damage to TV, trailer, or any third parties. I realize now what I did wrong. When I hooked up this morning, I had trouble getting the coupler latch to lock down. So I jumped up and down on the bumper to move the ball up and down slightly. When I did, the latch sprung down in place. I inserted the safety pin and took off. Problem was, the ball must not have been down in the coupler. It must have been just sitting on top of the ball. I still had part of the tongue weight on the jack, and the latch went down in place while sitting on top of the ball. I then fully retracted the jack and drove off unknowingly with the tongue just sitting on top of the hitch ball.
Praise the Lord this didn’t turn out worse. I normally hop on the interstate for about 10 miles to get back to my storage lot. But I had new brakes installed this week and wanted to go the backroads to hit some traffic lights and stop signs to get the brakes seated in a little bit.
I guess the moral of the story is you can never be too careful. I will definitely be sure to double check and make sure that hitch ball is properly seated down in the coupler from here on out. The safety chains did their job, but I’m glad I wasn’t traveling at highway speed, or this would have been much worse.
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
05-05-2020, 04:12 PM
You ain't the only one . I have been toting trailers for sixty years and have done it 4 times . No damage on any of them . All the times it was my wife,s fault . { Do not let her read this ] .
05-05-2020, 04:14 PM
Glad you and the trailer are ok.
We actually did that once, but my spouse spotted the problem before we pulled out of the lot. Just about the time you think you've got the routine down pat.... you don't.
2015 Dynamax REV 24TB class C
05-05-2020, 04:20 PM
Wow ! That could have been catastrophic for sure. Definitely a lesson learned, I had that a few times when I would have to just pull forward slightly just to get the latch fully locked,Scary stuff .Glad it turned out ok.
05-05-2020, 05:08 PM
Were the chains crossed to hold the tongue up? or was the tongue dragging on the ground.....Glad you dodged that bullet..
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD Diesel SLT short bed w/gravity flow75 gallon Fuel Tank.. Cat delete
Firestone Airbag Ride Rite system
05-05-2020, 05:22 PM
You are not the first and you won't be the last.
I had a home built race car trailer that the coupler was terrible for not going over the ball before the lever would pop shut and sit on top of the ball.
I guarantee you'll check and recheck from now on and it'll likely never happen again.
Glad it turned out well and glad you were able to understand what went wrong.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
05-05-2020, 05:35 PM
Make sure that the ball is well lubricated. Makes hooking up a lot easier... Ans safer.
2017 Rockwood 2304DS Ultralite
2012 F-150 4X4 XLT 5.0 V8
05-05-2020, 05:46 PM
On my trailer the chains are anchored to the trailer at a single point on the very front of the "A-Frame". Crossing them doesn't do a thing. Now if each chain was attached to the side of the "A-Frame" and a foot or so back from the front, different story.
As for making sure the coupler is firmly on the ball, I drop the hitch on the ball and if there's the slightest difficulty in latching it, I move tow venicle back and forth until I feel the coupler drop onto the ball. Latch then slips into place with a flip of the finger.
Even then I still cross my fingers until I've made it to the street and stopped a couple times
05-05-2020, 05:54 PM
My 18 foot toy hauler dropped after crossing RR tracks. Ground off the bottom of the tongue jack. Did manage to get it jacked up and reconnected and towed 80 miles home. Glad the safety chains held!
2019 Georgetown GT3 30X3
05-05-2020, 06:21 PM
Glad nothing bad happened. I can (almost) guarantee it won’t happen again!
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
05-05-2020, 06:23 PM
Glad you escaped with only minor damage! You've given me another reason to like my Propride hitch. There is never any doubt about hitching up properly. The only thing not clearly obvious is if the pin is in the receiver.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
05-05-2020, 07:15 PM
This serves as a good reminder to the rest of us. Thanks for sharing.
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
05-05-2020, 07:49 PM
Now a "Top Member"
I never dropped my TT or my boat, but I did "oops" a utility trailer before it ever left the driveway. I hooked it all up (I thought), then drove a scooter up the back. The front popped up and bashed into my tailgate. Put a deep scratch in it, but luckily that's all.
Glad yours wasn't as bad as it could have been.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
05-05-2020, 08:46 PM
Scoundrel
Given the circumstances, how lucky was it that this happened when you were attempting to seat new brake pads and took the back roads! Thanks for sharing your story. I'll be sure to check that the coupler is mounted correctly and the securing plate underneath the ball is secure.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
05-05-2020, 09:34 PM
#1 When I connect, I watch the ball enter into the coupler, and raise the jack until it is 1" off the jack pad, then if the coupler latch won't lock down, I "jiggle" the tow vehicle forward and backward a little bit, and it's usually the forward motion that lets the latch lock into place. That's the way my RV dealer showed me how to do it.
#2 Then as a second check you are actually locked onto the ball, lower the jack again and actually raised the back of the tow vehicle. I have to do this anyway to put on my weight distribution bars, but even if I was using weight distribution, it's a good second verification to do anyway.
My dealer told me lots of people try to pound the latch down, or bounce things up and down to get the latch down, but the way to ensure everything is really connected correctly is to move the tow vehicle slightly forward or reverse (usually forward) until the latch locks into place easily.
05-05-2020, 11:00 PM
Dropped my utility trailer once. Forgot to put the pin in the tow bar. Had the ball hooked up correctly but of course the draw bar disengaged from the truck. Embarrassing but luckily no damage.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
05-06-2020, 02:41 AM
Member: Old Man Club
Dang! My wife did that same exact thing! (and like wanderingbob said, she must not read this)
"Walk softly... and carry a lot of tools!"
2016 Ford F250 Super Duty Crew Cab, 4x4
2021 Palomino Puma 27RLSS
05-06-2020, 11:57 AM
Good reminder for me to double check. Glad nothing costly or damaging happened.
05-06-2020, 12:45 PM
X2 on #2
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
05-06-2020, 12:49 PM
Newbie
The chains appear to be attached at a single point so you can’t really cross them. The base of the tongue jack was dragging the pavement. Bent the base up a little, but jack still worked. Although it makes a lot more noise than before!
2015 Rockwood 2104S
