Duct work installed Flagstaff 26FKWS pic heavy
I got the duct work reinstalled in my trailer using much heavier triple ply (way heavier then stock duct) aluminum flex duct and 4" KD metal pipe by the tanks. All duct work is strapped up with fiber duct strap and air flow is much better. I did eliminate one run and combined the bedroom and bathroom on one run with dampers installed. Pic 1. T fitting with damper I installed to reduce air flow to bedroom and bath 2. run to bathroom and forward to kitchen. 3. run up left side of trailer to living room 4. Is T installed to bedroom and bathroom 5. Furnace with adjustable elbows and duct work installed. Each connection was taped and screwed I still have to tie up all the loose wiring.
Retired Navy
2016 Flagstaff 26 FKWS
