Old 05-21-2017, 11:19 PM   #1
Marshmallow Expert
MSgt Rick's Avatar
Dump station faux pas?
So, we were on our way home from our maiden voyage in our new TT (which was fantastic!), and needed to dump our tanks. Being that it was my first time doing so, I was nonchalantly watching other folks and it looked easy enough. The guy in front of me with a toy hauler pulled up to the dump station a bit close to the drain, so I figured that he must have a short sewer hose. Nope, NO HOSE: he put on rubber gloves and just opened the valve, letting the crap flow!!! He then grabbed the rinse hose, squirted down the area, took off his gloves and drove away.
Now, I know that I am new at the dump station, but that seems a bit wrong. Does anyone else do this? Is this an acceptable way of dumping black water? It "wreaked" of bad behavior!
Rick & Stephanie
2019 Toyota Tundra Crewmax TRD Sport
2018 Salem Cruise Lite 241QBXL
Whenever I feel blue, I start breathing again.
MSgt Rick is offline   Reply With Quote
Old 05-21-2017, 11:24 PM   #2
fonzie's Avatar
Not acceptable..
Fonzie
Old 05-22-2017, 12:16 AM   #3
NMWildcat's Avatar
Depends on how it's built. I've seen some built so that doing it that way would work. I would still probably use a short hose as I just don't want to smell it or get splattered
Scott and Liz - Southern NM
Old 05-22-2017, 12:43 AM   #4
asquared's Avatar
Definitely not sanitary, legal, or acceptable behavior. Anyone else see the irony in this guy using gloves to dump all over the ground?
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 05-22-2017, 01:10 AM   #5
I don't see a issue with using gloves,but I have seen Goof Balls throw disposable gloves down the sewer hole! I ask him why he did that and his reply was "The Campground Didn't put a Trash Can by the Dump Station! Takes all kinds and they "Reproduce"! Youroo!!
Old 05-22-2017, 04:54 AM   #6
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
You can't teach class. Some have it...some don't. (X2 on the fact they reproduce...sadly)
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 - 2019: 955 ~ Nights Camping 2020: 5 (Slowed a bit due to wife's knee replacement and then COVID-19)
rjshiflet is offline   Reply With Quote
Old 05-22-2017, 06:51 AM   #7
ManlyMan's Avatar
Itís completely unacceptable to dump without a sewer hose or other connection going into the sewer.
ManlyMan is offline   Reply With Quote
Old 05-22-2017, 07:04 AM   #8
Retired
MainelyUS's Avatar
In the words of Larry the Cable Guy "you can fix ugly but you can't fix stupid"
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
MainelyUS is offline   Reply With Quote
Old 05-22-2017, 07:32 AM   #9
Dumb...
One thing that I have noticed, however, is that retail establishments that offer free dump station use (mostly RV retailers) leave a hose connected to their dump station. If you think about it, this shortens the line immensely since there is no getting a hose out, connecting it, dumping and then flushing it and re-stowing it in the coach.
I bet that shortens the time per RV by more that 75%.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-22-2017, 07:42 AM   #10
While I agree it's not the most sanitary... there are several campgrounds around here where the dump station is built with curbing surrounding the dump port and the concrete trough slopes towards it. They are built to be used with NO hose. There is a sign posted that reads... Please rinse the area clean after dumping.
That said, I always use a hose but maybe this was one of those kinds of dump stations?
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 05-22-2017, 08:07 AM   #11
Picker our Dump stations around here are constructed the same as you describe with the Curb! BUT they are NOT built that way for "NO Hose Use" and the Signs/Notices reflect that! Maybe the mere fact the "Sewer Discharge Area" is/has been called "DUMP Station" people use it this way! Youroo!!
Old 05-22-2017, 08:24 AM   #12
I've seen the same thing, AFTER I try to figure out why the drain is plugged and not working.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 05-22-2017, 08:44 AM   #13
Marshmallow Expert
MSgt Rick's Avatar
No it wasn't that kind, the hole was vertically built into the base of the curb with a small trough running toward it. I have seen the type that you are talking about, but always assumed that you should use a hose for sanitary reasons (not to mention hiding the visual grossness of it). Maybe the one I used was designed for that purpose, but is sure wasn't pleasant to watch.
Rick & Stephanie
Old 05-22-2017, 08:44 AM   #14
Flybob's Avatar
The box constructed around some dump stations is there to contain accidental spills not for "no hose dumping" .
I've seen people throw their gloves in the dump station drain several times, when asked they usually say I don't want them in the RV and it can't hurt anything. Usually the same people that wonder why camping rates keep going up or complain when dump station is closed for repairs.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-22-2017, 08:53 AM   #15
NMWildcat's Avatar
I don't really care if the folks in front of me use a dump hose or not. The dumps I frequent have a basin around them and the hole opening is below the basin so anything in the basin drains well. As long as it is hosed off and ready for me to use, I'm good.
And I've never understood the gloves thing. I have a friend who dresses for a spacewalk anytime he has to dump any tank. Soap and water work fine for me.
Old 05-22-2017, 09:00 AM   #16
The dump stations with the curbing around them and the sloping to the hole is that way as a containment for an accidental spill not for use with no hose. And the rinse down sign is there to tell you to clean up when you are finished . I guess to say it saves time so you don't need to clean the hose is just like sating ( why wipe yourself , your only going to **** again ) Myself I will always use the hose to keep it as clean as possible and not need to look at it and smell all that stuff. I would not want to be the guy that had the site near the dump station and had to smell that no hose dump.
rickkey2 is offline   Reply With Quote
Old 05-22-2017, 09:06 AM   #17
NMWildcat's Avatar
Im just playing devil's advocate as I always use a hose, but the above is just an interpretation of the process. Someone else might look at it entirely different. I've never seen a sign saying you had to use a dump hose, and I can't see where it would be illegal as you are not dumping it on the ground.
Next time I'm alone at a dump station I might just try it. Sure would be nice to not have to drag out the dump hose
Old 05-22-2017, 09:08 AM   #18
I couldn't agree more. I think gloves give a false sense of cleanliness to people who use them.
I have a friend who uses gloves over and over again. Just throws them in the cargo area.
325BH is offline   Reply With Quote
Old 05-22-2017, 09:12 AM   #19
NMWildcat's Avatar
LOL!!!! Now that's funny. My friend puts on a plastic apron, rubber gloves that go past the elbow, and rubber galoshes. He actually had a face shield but even his wife laughed at that one. When's he's done, he cleans everything in a tub of Clorox water. We never wait for them on travel day. I'm going to have to look for pictures
Old 05-22-2017, 09:18 AM   #20
glsimms's Avatar
Don't know why, but I have visions of Robin Williams in "RV"......
We did see a similar thing happen last year. We were in line waiting to use the dump station and the guy ahead of us takes off the sewer cap and it came gushing out! I looked at the DW and said "Am I seeing what I think I'm seeing?" He says he thinks he forgot to close the black water valve, Ya think????
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
