Replacing the tongue jack with a powered one is very easy 3 bolts and a little wiring. There are several good ones out there and something around 1500 lbs capacity should be fine. I would run a good quality stranded # 14 wire to the 12V junction box on the hitch. Be sure to fuse it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
