Old 07-31-2021, 01:54 PM   #1
Ever see stains like this on a rubber roof?
I'm getting ready to recoat the roof on the Apex (with Heng's) and these stains are imbedded in the rubber. I tried Dicor roof cleaner and Star Brite mildew stain remover. The stains laughed. I'm not really too concerned that they won't come out, but would like to hear your thoughts. Have you ever coated over stains like this? I'm hoping that two coats will cover them, but again, not really concerned about looks, as long as they don't create a problem. BTW, the Star Brite did a much better job of cleaning the roof and I'm considering using that pre-coat. Of course I would rinse it thoroughly, but does anyone have anything to contribute on that as well?
TIA...
2018 Rockwood Signature Ultra Lite 8311WS
2014 Coachmen Apex 215RBK
2018 GMC Sierra 2500HD SLT Duramax
Chazman is offline   Reply With Quote
Old 08-01-2021, 07:32 AM   #2
SeaDog's Avatar
That doesn't look good. My first thought was mold however you treated the roof for that. I wonder if it could be the chemicals leaching out of the rubber covering sort of like what happens with vinyl in these rigs.
Retired Navy
2016 Flagstaff 26 FKWS
Old 08-01-2021, 08:55 AM   #3
Thanks for your reply. I think that's a good possibility. I almost thought it was supposed to be there, some sort of design(?) but knew better. There's more of it on the back half, which made me to think the trailer was parked partially under a tree. After cleaning I even tried scraping it a little with my fingernail. It's permanent. Really hoping it doesn't cause problems after I recoat...
Old 08-01-2021, 10:45 AM   #4
This looks like the roof on my old TT (a 95 Terry) with EPDM roof membrane.
Same issue, couldn't clean the spots off with anything. Turned out the spots were really the black EPDM showing through the white coating. A good cleaning with an acceptable roof cleaner and application of the new coating should handle the problem just fine.
Even if it was a mold/mildew problem, applying the coating after a couple of days of drying in the sun would merely encapsulate the mold/mildew. If the spores can't get water or light they can't grow so should be no problems.
That said my guess is just "holes in the coating" of the old roof.
FWIW, my TPO roof doesn't have this problem. Any spots are just dirt and they wash off easily with Dawn, Water, and Soft Scrub Brush.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 08-01-2021, 11:10 AM   #5
Thanks for your reply Mike. That's reassuring for sure.
Old 08-01-2021, 12:37 PM   #6
Global Nomad
Scheinin's Avatar
I have the same stains on my roof. Since they are even throughout the 40 feet of roof, I am not concerned.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Scheinin is offline   Reply With Quote
Old 08-01-2021, 01:19 PM   #7
Thanks for your reply Steven. Any idea what the cause is?
Old 08-01-2021, 02:31 PM   #8
Global Nomad
Scheinin's Avatar
No idea. But they just seem cosmetic, and not effecting roof performance.
Steven J. Scheinin
2015 RAM 3500 4X4
roo, roof
