10-24-2019, 03:00 PM
RS1 Duner
Fans at night
I want to run a fan in the day time or at night off the batteries but for some reason this does not work. I always have to start the generator to run fan. I have solar panels to keep batteries charged. I am at a loss as to why this won't work.
Any advice? Steer me in the right direction?? Thanks a million.
10-24-2019, 03:02 PM
Part-Time Campground Host
Is the fan 12 volt or 110 volt? In other words is it plugged into a wall outlet or hard wired to a small switch?
Craig & Cath
Days camped since 2015(retirement): 1415
10-24-2019, 03:06 PM
Almost all ceiling vent fans I've seen from the factory are 12v DC.
Is it possible you have a battery disconnect switch and you have the battery(ies) cut-off?
Even though the fan is 12v, AND if the battery(ies) are cut off, the fan would still work when you are on shore power because the CONverter would be supplying the 12v DC.
Also... I see you have just a few posts.
Welcome to the forum!
Please fill out your signature line with your R/V make and model (and any other pertinent information) so that information is included in each post for all to see. (unless you are using a mobile app, then we have to go look another place)
Whenever asking a question about anything, always include as much information about your unit and the appliance as possible.
Days Camped: '18=48 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=112 ☼ '23=72
10-24-2019, 03:25 PM
RS1 Duner
The fan(s) are 120v.
I will check the battery disconnect and get my signature thing fixed up. Thanks
Always Learning
Vent fans, yes.
My old fifth wheel had a hanging ceiling fan that was 120v.
10-24-2019, 03:29 PM
Batteries will not run fans that are 120 volt unless you have an inverter in the mix. Batteries are only 12 volt. That is why you need the generator to run the fans. Your generator puts out 110 volts.
Craig & Cath
10-24-2019, 03:43 PM
Always Learning
This is usually a new concept for a lot of RVers. I remember being confused when I first got my pop-up, the power outlets wouldn't work unless we were plugged in.
There are 2 separate power systems in your RV: 12v which is based on batteries and 120v which is more like household electric.
The 120v system is only powered by shore power, generator power, or some kind of inverter setup.
The 12v system can be used to make 120v but you have to install an inverter. Inverter installations can be as simple or complex as you'd like them to be. Simple is, attach inverter to battery or 12v cigarette plug and then run an extension cord to your 120v appliance. Complex is installing either an automatic transfer switch or an inverter with it built in to automatically switch between shore power and inverter power.
Do you currently have an inverter?
10-24-2019, 04:27 PM
You can get 12 volt fans to use at night. We have a 12 round outlet in the bedroom that you can plug a 12 volt fan into.
10-24-2019, 05:54 PM
RS1 Duner
Thank you ependydad
That totally make sense. I do not have an inverter.
