01-15-2021, 06:51 PM
Fifth wheel hitch with bedliner
As always to Admins, move if duplicate.
I purchased a 2020 GMC 2500 HD to tow my fifth wheel trailer. It has the standard, factory installed bedliner. Anyone have experience with installing a hitch with this bedliner (Denali)? I'll probably have a Curt installed (maybe a Reese) non-sliding (I have a Turning Point king pin). Do I need to remove the whole bedliner? Can I cut and seal it? I don't want water, sand and grit getting between the liner and floor of to box. All opinions appreciated.
2021 Flagstaff 528RWS
2020 GMC 2500HD Diesel
2019 Labrador Retriever
1983 Wife
01-15-2021, 07:22 PM
If you don't want sand etc between the bed liner and the bed............. best bet is to use a spray in liner and get rid of the factory one.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
01-15-2021, 07:24 PM
Interesting question. The bedliner in my 2019 Duramax was sprayed in -- not a separate piece.
On an earlier truck, my installation involved cutting slots in the removable bedliner so that the rails would install metal to metal. On the rare occasion I had bedliner out, I seem to recall there was abrasive wear on the bed from the liner itself shifting around, not particularly from intrusive grit.
Hope this helps.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
01-15-2021, 07:25 PM
I agree. Spray in bed liners are the cats meow.
but they are hard on the knees climbing in and out of bed with shorts on.
01-15-2021, 09:22 PM
I've had drop in liners in previous trucks. This one is odd in that it doesn't look like a drop in or a spray in and I see no obvious points of attachment. I'll just take it to the installer and see what they think. Thanks for the comments!!
1983 Wife
01-15-2021, 09:30 PM
Now a "Top Member"
My first truck had the drop in bedliner, and I just had it cut for the installation of the hitch. I had no problems with it, but then again, I didn't really pay close attention to it. The trick was made to work, and that what it did. My current truck I had the spray in bedliner. Maintenance free (mostly), durable, and no need to worry about it. But yeah, it is pretty rough on the knees, and any other parts of your exposed skin.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
01-16-2021, 01:25 PM
X2
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
01-16-2021, 02:22 PM
I have a 2500 Chevrolet Duramax and the bed liner is sprayed in. I have puck system so there are four removable caps to secure your hitch. Most manufactures make one for the puck systems. Easy to install and secure. We are using Pull-rite. Very happy with it.
01-16-2021, 02:28 PM
you could go with a b and m turnover ball . ranch hitch adarpter . " easy self install on fithwheel" or a companion hitch set up.
01-16-2021, 02:32 PM
BMullins46
Like others have said I'd get rid of the drop in bed liner, they are so slippery when wet., all they are good for is making you fall. Spend the $500-600 and have a spray in bed liner installed.
Bill Mullins
2016 XLR Thunderbolt 385AMP
2012 Ford F350 DW 6.7 Power Stroke
01-16-2021, 02:57 PM
Wow, lots of opinions here on bedliners but not many answers to his question about the hitch. If you're installing industry standard rails, you'll need to cut the liner so the rails can mount straight to the bed. If you're installing factory puck system, you'll need to cut opening for each puck and for the gooseneck opening.
George & Nancy, Allen, Texas
2015 F350 CC, DRW, LB, Platinum Edition
2018 Cedar Creek 36CK2
01-16-2021, 03:12 PM
you can turn the bedliner upside down and make a redneck bed cover. 2 ratchet straps , keep contents dry . got complements on it in a rainy day in colorado.
01-16-2021, 04:14 PM
Fla5er
When I bought my '05 Duramax Diesel we had the intention of installing a fifth wheel hitch, so we had a Line-X spray in bed liner done before the installation of the hitch. No problems with it at all. Line-X has a lifetime warranty with it so I would consider Line-X for the bed in your truck. There are other manufacturers of spray ins, but I preferred Line-X.
01-16-2021, 05:50 PM
My 04 pickup had a Rhino liner and my 14 has the factory spray on my hitch rails were installed right on top of the liners and never had any problems with many miles of towing.
01-16-2021, 06:37 PM
Does your new truck not have the fifth wheel prep package, puck system? I would expect that in a new HD truck
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
01-16-2021, 08:12 PM
Befuddled wanderer
My current truck has a drop in bed liner. The rails for the fifth wheel hitch are bolted directly to the floor of the bed and the bed liner just sits on top of them. There are holes cut in the bed liner where the hitch needs to fit through to sit down on the rails properly. I bought the truck from my Dad with this setup already in place and I've never quite felt like spending the $'s to have a spray in bed liner installed. If I had purchased the truck without a bed liner included, I would have had the spray in version installed.
Having those holes cut in the bed liner allows some debris to get underneath it, but I have found that it's not that big of a deal to pull the liner out and hose out the bed of the truck once in a while.
01-16-2021, 10:07 PM
New to FR. Old to TT
If the OP has a factory Denali it is a spray in and no you dont need to do any thing but put the hitch in. Based on what OP said he has a rear pivot king pin so he can't use a goose ball mounting hitch. Using the built in puck system will prevent any sliding or rubbing on the bed liner, even so that stuff is almost indestructible. I have it in my truck and no problems
01-17-2021, 08:04 AM
Yes I agree get rid of that drop in bed liner and go with spray in you won’t be sorry
01-17-2021, 02:19 PM
Yes, I just looked at my specs and is says CGN-Bed Liner, Spray-on. It doesn't look like spray-ons I have in the past so it made me think it was a drop in. I have the 6 3/4 foot box and the dealer said the Turning Point king pin does not require a sliding hitch; however, some have recommended getting one anyway should I ever want to change RVs. Thanks to everyone for the information. If I'd just pulled my Vehicle Information Sheet I could have answered my own question.
1983 Wife
01-17-2021, 06:49 PM
You don't need the sliding hitch, about 80lb more weight and more things that will need maintenance.
We have an Andersen 5th wheel hitch and use the goose ball as an anchor point. I can get about 80deg. Turning with our CC36CK2
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
