Being seasonal going on 10 years a couple things:
* doubt they will hook up sewer and water hoses
* if your water hose is hooked to city water inlet your on board water tank shouldn't
fill, no need to if your hooked to city water. If it does there is a problem with the
check valve on the water pump which you don't run when on city water.
* you don't mention the year or model of your camper but many have a switch on
the water heater itself to turn on the electricity to your water heater. This is in
addition to the interior switch to run water heater on electric. This is meant as a
reminder to fill the water heater tank first to prevent burning out the heating
element.
* most campgrounds are equipped to fill LP tanks.
* campground employees work for the campground, many aren't familiar with how
camper systems work. Your best bet for help at the campground is fellow campers
who will probably be happy to help. Plus it's a great ice breaker.
* water heater anode wear diagram:
