Can you find the panel on the outside of the rig where the water heater is? It's usually a vented cover and can be easily removed. You should be able to see a propane line and it should have an on/off switch for the electric. That should tell you if you have propane and electric.
There should be a switch on the wall to turn on the water heater with propane. If it lights up when you turn it on and stays lit, then you may be out of propane.
You're plugged into a campground outlet? If you have electric and have water, it should heat automatically unless the electric element has burned out. If it was running on propane and that isn't working and the electric element was turned off or burned out, that could be possible.
It's also possible that the electric in the water heater is off or needs to be reset, but we'd need the make of the water heater to help further.
Welcome to the forum.
2015 Dynamax REV 24TB class C
