Old 05-11-2021, 04:58 PM   #1
Cool FR3 Clicking
I own an FR3 30ds. When the batteries are fully charged I hear a clicking noise from the battery compartment. Any ideas?
Captin53 is offline   Reply With Quote
Old 05-12-2021, 01:32 PM   #2
NXR
NXR's Avatar
An occasional clicking or what? Is it truly a "click", which usually means a softer, quieter noise? Or is it more of a louder "clunk"?
What year FR3 do you have?
In the battery compartment you should have a device called a Battery Control Center. Which one do you have?
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 05-12-2021, 03:40 PM   #3
Clicking
The Motorhome is a 2015 with a Battery Control Center. I think the clicking (not Clunk) comes from the Control, Center.
Old 05-12-2021, 05:59 PM   #4
bubbles's Avatar
The interconnect relay (solenoid) is inside the BCC and it will change state (energize/deenergize) as applicable when on shore/generator power and when engine is running for cross charging (coach/chassis) batteries to control over charging. Normal operation. If one of the conditions above is not the case; I haven't a clue.
Old 05-21-2021, 01:06 AM   #5
The clicking sound you’re referring to is similar to the sound you hear when you disconnect the batteries on the battery control center. If so, then @bubbles described normal operation.
FR3 30DS
leonards is offline   Reply With Quote
fr3
