When you 'drained' it, did you use the drain port or did you just run the pump until it quit pumping water? You could get two different quantities depending on which you used.
The mfg's use total capacity of water, not usable capacity. So the tank, lines, filter and water heater could hold 44 gallons, but you'll never be able to use that much. Yeah, it's kinda deceptive, but that's how they do it.
You may be able to move the pump suction tube to a lower port or you may be able to add an extension to the existing tube in order to get a little more water out of the tank. But you're never going to get a usable 44 gallons with the factory set up.
Gotta go campin!
