Furrion FOS48TAPK-BL Camera Surprise
My 2018 Forest River Wildwood 254RLXL came "pre-wired" for the Furrion backup camera. Although cheaper cameras seem to be available, I decided to go with purchasing the Furrion 381556 FOS48TAPK-BL Wireless High-Speed RV Observation System because it was reputed to be "easy to install". In theory, you just climbed a ladder, popped off the pre-installed bracket cover plate, connected the camera to the pre-existing power connector, screwed the camera into place, and voila, you're done. Well it turned out to be NOT so easy. First, Furrion apparently has upgraded the camera, bracket, and connector. Of course, the bracket mounting holes are SLIGHTLY different, the connector is a totally DIFFERENT style, and you have to change out the bracket - the upgraded camera doesn't fit the pre-installed bracket. Okay. So I removed the old bracket, installed the new bracket, cut off the old connector, spliced in the new connector, and was able to re-use two of the four original mounting holes to hold the bracket and camera to the back of the trailer. I will rely on them plus the silicone to hold the new bracket in place so I don't have to drill two new holes into the sheet metal. Seems to work fine, BUT the pre-installed power cable appears to be LIVE all the time. I thought it was to be live only when the marker lights were on so that the battery wasn't drained unnecessarily. I'm open for advice here. 1) where did the pre-installation pick up a live feed instead of from the marker lights? From the interior ceiling lights? 2) how important is it to undo the existing constant live feed to fish out and splice in the marker light feed instead? My final comment is that it seems Forest River's job of "pre-wiring" this trailer for the Furrion was unusual, outdated, and not very helpful. Am I missing something?
/s/ George Hay Kain, III - 2018 Forest River Wildwood 254RLXL; 2013 Ford F-150 3.5 EcoBoost 4x4; ZEEPIN TPMS Solar Power Wireless Tire Pressure Monitoring System; Sherline LM 2000 - Trailer Tongue Weight Scale 2000 lb; Furrion 381556 FOS48TAPK-BL Wireless High-Speed RV Observation System.
