Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 08-25-2021, 07:27 PM   #1
Gas can?
I need a good gas can to bring for my generator and an easy way to store it. I heard the metal Jerry cans are good; I'm having trouble finding metal ones that look decent..
What are the best options (with links if possible?) and where is everyone storing it on a fifth wheel RV?
Thanks!
exponentfrost is offline   Reply With Quote
Old 08-25-2021, 07:52 PM   #2
If I was hauling gas, I would carry it in the bed of the truck, where it can breath safely.
I am planning to haul a couple of cans for diesel for the truck and will put those in the nose compartment of the 5er.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
mmartin_tdc is offline   Reply With Quote
Old 08-25-2021, 08:15 PM   #3
I'm picking up the RV later this week but - can one safely haul a jerry can gas can in the bed of a truck (or for that matter anything else) with a fifth wheel RV?
Old 08-25-2021, 08:37 PM   #4
I haul a gas can in the bed of my truck every time I take the generator. No big deal. I just use a red plastic gas can.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 6 Speed 3.42
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 08-25-2021, 08:39 PM   #5
I haul my generator and a couple gas cans (along with lots of other stuff) in my truck bed often when towing our 5th wheel.Click image for larger version
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=19
Old 08-25-2021, 08:40 PM   #6
I love this one. I keep it filled with ethanol free gas from the local landscaping place.
https://www.amazon.com/Surecan-Venti...9941923&sr=8-2
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL
Andersen Ultimate
800W solar > 412 Ah LiFePO4 > Victron MultiPlus II
corn18 is online now   Reply With Quote
Old 08-25-2021, 08:56 PM   #7
I use this, the spout and rear handle are great for filling my Hondas. My complaint is that the container is so thin it balloons in the heat badly.
Northern Indiana
2018 Salem Cruise Lite M-241QBXL
2018 GMC Canyon Denali
Rick the Rocket is offline   Reply With Quote
Old 08-25-2021, 09:18 PM   #8
That container is awesome. I forgot my spare once and went to the several hardware store which were all out of five gallon cans. Found the Surecan and very reluctantly bought it for just over $40. After six years of continuous use it still performs flawlessly. Nice to be able to place the can in a stable spot, move the flexible spout to the fill opening then start and control the flow of gas with the top lever.
Old 08-25-2021, 09:21 PM   #9
I have bought so many gas cans till I found this.
Do yourself a favor and get this for your last gas can.
https://www.justrite.com/type-ii-acc...BoCzU8QAvD_BwE
2015 silverback 31IK
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 08-26-2021, 09:01 AM   #10
I have an Eagle brand 5g safety can. Doesn't need the goofy safeties that come with the plastic jugs. Available on Amazon and other sellers.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 08-26-2021, 09:05 AM   #11
Just Tryin' to Help
cboss's Avatar
Just press the button to let the air out.
I really like these "No Spills".
We carry three of the 2.5 Gal ones in the truck bed.
Also, the spout is self stopping like at the gas stations.
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1135
cboss is offline   Reply With Quote
Old 08-26-2021, 09:37 AM   #12
I agree the benefits out way the downside. The expansion while sitting the garage concerns me (given the cost of this can). I have plastic storage containers from the 1980's that are engineered in ways that this doesn't happen.
As a aside I carry my gen gas in the bed of the tow vehicle.
Northern Indiana
Old 08-26-2021, 09:48 AM   #13
I have a gas container just like this. I deal with the expansion issue by squeezing the sides against side of pickup bed while holding calve open. Then let valve close. This allows for expansion without ballooning container.
Another method I've used is to just "burp" container on a cold morning.
Never been a problem with leaking.
For my extended boondocking trips i carry 2-5gal and one 2-1/2 gal tank. Also a battery operated transfer pump to refill small can that's used to fill generator.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 08-26-2021, 10:20 AM   #14
X2. The only thing I will add is to pick up an extra spout. Mine cracked at the elbow and started leaking. After getting a replacement, I noticed how much stress pushing it into it's storage slot put on the elbow, so I leave it pushed up to the can loose.
latner is offline   Reply With Quote
Old 08-26-2021, 10:28 AM   #15
trailerdude's Avatar
If you want a really sturdy gas container check out Rotopax. All the Jeep guys use them. I got a 2 gallon one and mounted on the front frame of the trailer. It is really thick and strong.
https://www.forestriverforums.com/fo...-195659-3.html
2020 Rockwood 2104s towed by 2018 Nissan Armada. Curt WDH with sway, portable 150 watt solar, Home made window evaporative cooler
trailerdude is offline   Reply With Quote
Old 08-26-2021, 11:05 AM   #16
NMWildcat's Avatar
Buy any gas can you want, spend as much or as little as you desire, then throw away all the safety crap on it. Install this kit and enjoy!
https://www.tractorsupply.com/tsc/pr...RoC3hAQAvD_BwE
Scott and Liz - Southern NM
Old 08-26-2021, 11:13 AM   #17
X2
Just be aware... EZ-Pour makes two different diameter spouts!
I find the large one OK for filling bull dozers, front end loaders and heavy equipment but the liquid comes out way too fast for generators and lawn mowers. Make sure you get the smaller diameter one for those jobs.
Old 08-26-2021, 01:48 PM   #18
I also love this gas can. It is the only easy to use modern gas can I have found.
Aladin Sane is offline   Reply With Quote
Old 08-26-2021, 02:05 PM   #19
grege's Avatar
Love my EZ Pour spouts. I have the larger diameter for my diesel can so I can fill my truck faster. Have the smaller one for my unleaded gas so I can control it in my mower easier. I also have 2 transfer pumps from Harbor Freight and use them sometimes.
I recently had to replace the gaskets on my spouts and bought some solid caps to keep on the cans instead of the spouts since they were hitting my truck cover when I would retract it.
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
grege is offline   Reply With Quote
Old 08-26-2021, 02:16 PM   #20
KyDan's Avatar
The original post was asking about WWII/Korean war metal jerry cans.
Not a single response about where to get one so we gotta guess they are not made any more.
Did you try Army surplus stores??
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41, 2021-49
gas
