HELP! 2013 Class C Solera/Mercedes Running Lights
Rear running lights and upper back red/front amber running lights are not working. Front headlights/amber running lights turn on. Rear lights work when apply brake, turn signals and hazard lights. We have checked all fuses that could be associated with lights under steering wheel, drivers seat and below oven. All fuses, even when tested are fine. There is no current to #7 pin on trailer hook up plug. Opinions so far are grounds should be OK since lights work when brake/turn/hazard initiated, so probable cause is in-line wiring disconnected somewhere. Is there an in-line fuse anywhere, and what are most probable places I should look for wiring to see where the problem is? Or how do I even start checking and what should I look for? Hopefully the forum can point me in the right direction......
