Originally Posted by chief5631
Thanks for the input. another question...Why wouldn't OTA stations come in if I am only 43 miles away from the main tv stations? The OTA says 100 miles? And then one main station will come in perfectly sometimes for hours and not be reachable any longer?
Digital TV has much less power and much more finicky that analog ever was. First off, you need to point the face of the antenna toward the tower, which you are trying to pick up. To do that, you'll need to know which way the antenna actually faces. 90% of the time, it is NOT the little arrow on the front of your antenna direction dial (little pull down mechanism you turn to change the direction of the antenna). I had to look on the roof to see how the antenna was installed and then put a little mark of the inside handle to show which way it faced.
43 miles away SHOULD work fine, but if you have a lot of trees, a couple of hills, etc. in between you and that signal, it can keep you from receiving it during certain parts of the day. I was in one campground and we had transmitters only 25 miles away. However, they were on the other side of the mountain, so we couldn't receive any of the channels from it.
Nighttime is the best time to receive the tv signals. You will likely find you can receive more channels during the night, than during the day.
Get an app, which shows you the direction you need to point, or use a compass and the FCC list the towers to aim your antenna toward the tower needed for the channel you want to receive.
Good luck with the wiring. It can be a pain to troubleshoot wiring problems.
