Old 08-30-2020, 08:42 AM   #1
Hiding in the walls of a trailer
Critter proofing trailer and opened up all hatches and panels to seal any entry points. Checked behind furnace with the phone cam and saw something. Thought it was an antenna at 1st. This must have been there from the factory. And the thing still has power.Click image for larger version
ID:	237983Click image for larger version
Chris
2012 28 ft Cherokee Grey WolfBHKS
2014 F150 4X4 Supercrew 5.0 XLT XTR
Lexa is offline   Reply With Quote
Old 08-30-2020, 08:47 AM   #2
Chris Pastuzyn's Avatar
That is a big critter, That's way better then 10lbs of screws that someone else found .Amazing!
Chris Pastuzyn is offline   Reply With Quote
Old 08-30-2020, 08:49 AM   #3
Now that is a pleasant surprise. I found saw dust, wood chips, 1/2# of screws, dozen or more wire nuts.
TheWolfPaq82 is offline   Reply With Quote
Old 08-30-2020, 08:50 AM   #4
PhD, Common Sense
The most concerning thing you found hiding behind that wall was wasted space!
eye95 is offline   Reply With Quote
Old 08-30-2020, 10:09 AM   #5
Lots of that in these things.
Chris
Old 08-30-2020, 01:19 PM   #6
Bad omen. Maybe they left it where you would find it. And as a part of QC, where you would need it. As others have mentioned in other parts of this forum. The weight when it leaves the factory is more than the listed dry weight. You just proved it!
PenJoe is offline   Reply With Quote
Old 08-30-2020, 02:02 PM   #7
Anybody seen my screwdriver? Recovering that puppy will cover part of the down payment! :-)
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 08-30-2020, 02:04 PM   #8
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Nice find!! Will be you able to charge the battery or do you need to purchase an adapter? Either way, that's a nice drill!!!
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
Lloydg is offline   Reply With Quote
Old 08-30-2020, 03:56 PM   #9
Lots of chargers at work.
Chris
Old 08-30-2020, 03:57 PM   #10
I was thinking the same. Only a few pounds off but they most like print those weight stickers in mass quantity.
Chris
Old 08-30-2020, 06:04 PM   #11
Herk7769's Avatar
If you return it to the technician who lost it at the plant, they will give you a brand new camper.
HAM CALLSIGN - KC3FFW
Old 08-30-2020, 06:06 PM   #12
Nope. To many issues with new. I'll keep the driver. ;-)
Chris
Old 08-30-2020, 06:21 PM   #13
PhD, Common Sense
I always assumed that every RV was weighed upon completion as it was intended to be sold, and a unique sticker generated for that RV.
Old 08-30-2020, 06:23 PM   #14
Idk. I'm just talking shi!
Chris
Old 08-31-2020, 08:30 AM   #15
Cool discovery which brings up this rhetorical thought. If the RV assembly person is negligent enough to forget the whereabouts of tools, does the negligent mindset affect the assembly quality of the RV?
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 08-31-2020, 08:37 AM   #16
That's why I never buy new. Let the original owners work out the issues.
Chris
Old 08-31-2020, 08:39 AM   #17
If the drill could talk, I would bet it was left there at the end of a Friday afternoon shift.
Old 08-31-2020, 08:42 AM   #18
Assembly line worker was denied a new tool so they had it "lost" in the walls of the RV. New tool accomplished!
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
jd4010 is offline   Reply With Quote
Old 08-31-2020, 08:49 AM   #19
The problem I see is that looks like an impact driver and you really shouldn't be driving screws with one of those.
Michael and Pamela
Colorado Springs, CO
2017 Roo 233s
Towed by 2016 Ford F-150 screw, ecoboost, maxtow
Replaced 2011 Ford F-150 screw, ecoboost, maxtow
that overheated every time it towed up hill.
joeuncool is offline   Reply With Quote
Old 08-31-2020, 09:25 AM   #20
BriaBeck's Avatar
It all depends on which screws you are driving... and depends even more on the skill of the tool operator.
This could be a tool that belonged to a "bottom worker" that got buried by a "top worker".
I so far, I have found 2 utility knives in our Avenger from the production line.
Brian & Becky
2018 Avenger ATI 27RBS
Champion 3500
Weber Q2000, Blackstone 22", and a whole herd of flamingoes
BriaBeck is offline   Reply With Quote
trailer
