08-31-2021, 09:53 AM
Hitch bike carrier for fifth wheel?
I have a fifth wheel, I'm going to add a hitch receiver to the bumper so I can bring our bikes- I'd prefer the hitch style so when we get where we're going I can use it on my truck as well. Problem is all the hitch style bike holders say not rated for campers. Has anyone used these on a camper bumper without issue or found one rated for a camper bumper?
My bumper is rated for 300lbs(I'll need a 5 bike carrier, 2 adult bikes and 3 kid bikes ). I'll leave my bike in the camper when traveling to decrease stress on the bumper.
Thanks for any advice!
08-31-2021, 09:57 AM
Check etrailer for the different types.
We found one that was approved for use behind a toad there.
They have search so you can find the different ones that are approved for use behind campers etc.
2014 3051S - First RV for us
2022 DX3 RB on order
08-31-2021, 09:59 PM
You are not going to be able to safely carry several bikes on a bumper style carrier. Camper bumpers just aren't designed for this. Look into adding a frame mounted dual hitch point bike carrier and let the bumper add some support to this rack.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
08-31-2021, 10:58 PM
Like this?
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
09-01-2021, 09:41 AM
hitch
As others have said, bumper will not handle 5bikes.
Hitch needs to be connected to the frame.
See below example
Note bolt on top of receiver tube. bolt is tightened and jam nutted to to keep bike rack from bouncing in receiver tube like you see in the video.
09-01-2021, 11:32 AM
Take your RV to a local welder, an RV shop that also welds, or a hitch installer, and have them weld a hitch with supports to your frame after describing what weight you need to support. Then buy whatever bike rack you want.
Numerous RVers I know (including myself) have done this and never had a problem. I was also surprised at how cheaply this safe and secure mod can be accomplished.
Scott and Liz - Southern NM
09-01-2021, 12:14 PM
As has been mentioned, DO NOT add a hitch receiver to the bumper whether it is rated for 300 lbs. or not. That rating IS NOT for something hanging off the rear of the bumper by a couple feet bouncing around.
Do what others have suggested and find someone who will build, bolt or weld a receiver to your frame. Then buy whatever bike holder you feel would be a good fit for the bikes you own.
As NMWildcat says, once you have a hitch receiver as secure as something on an automobile/truck, I have not seen any issues with them just because they are on the back of a trailer. It's the ones mounted to flimsy bumpers that will break and drag the bikes down the highway... or worse... come off on the highway.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 ☼ '18=49 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=88
09-01-2021, 03:33 PM
Correct on those posts. 300lbs applied in which way? Certainly not twisting force. Probably vertical load. Once it starts extending behind the bumper the applied load increases.
09-01-2021, 04:31 PM
My used fifth wheel came with a receiver welded to the frame and also supported by the rear bumper. I used it to carry two adult bikes utilizing a wheel mount style carrier I already had. After one season of doing this (last year with reduced camping trips), I switched to a roof mount rack for my tow vehicle. The bikes took a total beating. Headlights lost lens. Brake and shift cables lost supports and subsequently broke. I am much happier with the bikes on the top of the pickup truck. Roof rack cost more than I wanted to spend when I started taking them camping. After what I have paid to fix the bikes, I wish I had bit the bullet to start.
F450 SuperCrew 8' bed
Salem 27RKSS 5'er
09-01-2021, 08:02 PM
I don’t think I would want to put my E-bikes up there.
09-02-2021, 08:43 AM
This is what you need. It bothers me to even hang my spare tire on the box bumper. I had mine reinforced by the welder guy that installed my hitch.
https://www.amazon.com/CURT-13703-Ad...0590137&sr=8-4
Five bikes will be a load. You may want to split them up between a rear mount, and a front mount rack.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
09-02-2021, 12:38 PM
Try this link: https://www.carparts.com/search?q=trailer_hitch.
This is the old JC Whitney catalog now called CarParts.Com. I bought a hitch from them back when I had a Ford Escape and it was the best darn hitch, better than anything you see from Hidden Hitch, Reese or anything U-Haul installs.
Check under your trailer to see which mount style will fit. Most hitches are "bolted" to the frame not welded.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
09-02-2021, 12:57 PM
Have Camera will Travel
Another solution is have a front mount hitch on the tow vehicle. We did that with our C class. Its overkill with a max 750 lb tongue weight but it also gives you a place pull from if you ever get stuck.
2018 Sunseeker 2430S-CD
Ex Canadream Rental
09-02-2021, 05:11 PM
a cheaper alternative, just for bikes, is a universal receiver hitch that bolts to the rear frame rails, https://www.etrailer.com/RV-and-Camp...urt/13703.html
09-02-2021, 06:23 PM
Originally Posted by nayther
I disagree. My weldup job was cheaper AND more sturdy!
09-03-2021, 09:02 AM
hitch
I disagree. My weld up job was cheaper AND more sturdy!
Totally agree.
C.B.
09-03-2021, 10:13 AM
Originally Posted by cbvp
Totally agree.
C.B.
I had my welder reinforce my factory frame mounted hitch on the back of my 5er. I think the whole back of my trailer would have to rip off for that thing to fail.
I use the Thule Easy Fold XT2 ebike rack on the back of our 5er. It is built like a tank and we can see it in the rear view camera. It wiggles but it doesn't bounce and we have been over some awful roads. I like our setup and am confident it will hold up.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL
Andersen Ultimate
1200W solar > 412 Ah LiFePO4 > Victron MultiPlus II > Cerbo GX
09-05-2021, 12:10 AM
Retired Engineer
Bike Rack Must be "Trailer Rated"
There are two issues:
1. Receiver must be mounted to the frame - not the bumper.
2. The bike rack must be "trailer rated". "RV Rated" is not good enough. You have to really dig through a bike rack manual to find out whether it is trailer rated. The vast majority are not - and they don't mention that in their adds or on the box. Trailers have a side-to-side oscillation at a rate of about once per 1.5 seconds. Metal fatigue causes the racks to fail and fall off.
And, I have been trying to buy a trailer-rated bike rack for the last 6 months with no luck - backordered with no promised delivery date.
