Old 05-26-2016, 08:51 PM   #1
Holding tank vent stack never caulked
So I'm replacing a broken holding tank vent cap and then it all goes wrong. I remove the broken cap and Dicor sealant and discover a big gap around the vent pipe open to the ceiling below. No caulk surrounding the vent stack at all plus crummy job of cutting wood around vent stack. My question is, should I use spray in insulation and then caulk on top of that, stuff fiberglass insulation in there and then caulk or......? Any suggestions out there?
wildwoodtraveler is offline   Reply With Quote
Old 05-27-2016, 12:04 PM   #2
A lot of the vent stacks aren't sealed to the roof. The vent cap seals to the pipe, but it's a good idea to seal the membrane to the pipe. I'd use some window and door spray foam and then run a strip of butyl tape around the pipe flared out onto the roof. Then I'd apply some lap sealant on top of that.
Then I'd install the cap over that and seal it up well.
Gotta go campin!
Old 05-27-2016, 08:48 PM   #3
Thank you for the tips. I tweaked it a bit. First sealedl roof to pipe with Eternabond, then Dicor around pipe, then butyl tape to bottom of vent cap, pressed cap down until butyl seeped out of sides a bit, trimmed edges, then Dicor in screw slots prior to setting screws, then Dicor to vent cap edges and over top. Yes, probably overkill, but I think that will do it and I can stop worrying about it.
caulk, tank, vent
