Originally Posted by markb422
There are absorption type refrigerators that run on LP gas why don't they make a absorption air conditioner that runs on LP gas? Even if it only did 80 degrees on a 100 degree day and take the humidity out of the air.
A Dometic DM2652 fridge uses 1500 BTU/hr on LP gas. An AC unit runs 13,500 or 15,000 BTU/hr depending on which size you have. So a 15,000 BTU AC unit is 10 times larger than a fridge. Imagine the size of the absorption unit it would take to run a 15,000 BTU/hr AC unit.
And the amount of LP gas you'd use: 1 lb of propane is 21,600 BTU's, so you'd use a lb of propane every ~1.5 hrs.
And notice that a number of RV fridges are starting to go to 12VDC compressor units.
2011 Traverse LT, 3.6L, FWD
