Old 08-29-2020, 07:43 AM   #1
Nwnjguy
How to change puck lights?
I just bought 2011 Georgetown. How do you change the Puck light that is out? Tia
Nwnjguy is offline   Reply With Quote
Old 08-29-2020, 07:50 AM   #2
Part-Time Campground Host
cboss's Avatar
A pic would help, but most of them you can carefully pry off the lens. Then you will see the screws attaching it to the ceiling or whatever. Unscrew and the wires are probably wire nutted. Replace with new light.
Craig & Cath
Days camped since 2015(retirement): 1423
cboss is offline   Reply With Quote
Old 08-29-2020, 10:51 AM   #3
Nwnjguy
lights picture
This is the Puck Light in question. I tried turning but it doesn't, also prying with my fingers. neither seems to work. am i supposed to lift the bottom of inside the cabinet?
ID:	237921   Click image for larger version
Old 08-29-2020, 11:26 AM   #4
bubbles's Avatar
'm pretty sure those are pull straight down lights that have spring tensioners on the backside.
light
