Old 07-12-2021, 04:33 PM   #1
Hydraulic level system - I need help
After setting up the Camper today, I noticed that the middle and rear jacks on the entrance side of the camper were not touching the ground.
I went ahead and retracted all the jacks and performed the auto level again. Same results. Any ideas?
Randy in Texas
TV - 2013 Ford F-250 PS Diesel
TT - 2014 Palomino Puma 28DSBS
Grif76040 is offline   Reply With Quote
Old 07-12-2021, 04:36 PM   #2
ID:	258921Click image for larger version
ID:	258922Click image for larger version
ID:	258923Click image for larger version
Randy in Texas
Old 07-12-2021, 05:18 PM   #3
i'm not familiar with that brand of leveler. does it have a manual option? if so will the jacks respond to manual input? have you contacted the jack manufacturer's tech support?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 07-12-2021, 06:40 PM   #4
They do respond in manual mode. I have not contacted Lippert.
Randy in Texas
Old 07-12-2021, 07:42 PM   #5
Retired JSO's Avatar
Had that same problem after a few trips with our Cardinal when new. Using a flash light, I went in the front compartment above the batteries on drivers side and discovered a wire had come loose from the valve body.
Retired JSO is offline   Reply With Quote
Old 07-12-2021, 07:44 PM   #6
rracer5's Avatar
Try manually leveling the trailer using a 2 or 4 foot level on the entry door front to rear then left to right. Then perform a "zero point calibration" per the instructions on page 9.
https://lci-support-doc.s3.amazonaws...cd-0001539.pdf
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-13-2021, 12:38 PM   #7
I am also working on that problem right now. Was first diagnosed as the leveling controller being defective but that didn't solve the problem.
Now diagnosed as a sensor problem. Sensor is located behind the rear wheels and requires removing the bottom of the trailer to get to it. I should know if a few days if that fixed the issue.
modem9 is offline   Reply With Quote
Old 07-13-2021, 01:08 PM   #8
I have Lippert 4 point levelers and have found wheels off the ground on occasion. I then relevel using manual mode and the trailer does get level. I'm not sure why this happens, but then I'm also not sure why the first step in the instructions is "Park the RV on level ground." Seems to me if I could always find level ground to park on, I wouldn't need levelers.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 07-13-2021, 01:56 PM   #9
Thanks for the information
Randy in Texas
Old 07-13-2021, 01:57 PM   #10
Please keep me updated
Randy in Texas
hydraulic
