07-03-2021, 12:25 AM
I should have checked my waste hose before going camping...
First shakedown cruise for the new TT.
Spent the morning putting the SoftStart back up and then most of the early afternoon cleaning and putting our stuff into the TT for what is actually just a quick 2 night trip.
Thanks to people who for unknown reasons decided to get into accidents on perfectly good sunny day, what would have been a 2.5 hour drive stretched into over 4 hours and we got to the campground about 20 minutes before it got dark. I hurried to get the TT level, tongue & stabilizers set, plug in shore power and water, and it was dark. By the time I realized the gray water tank was near full, it was 11pm. I went outside and connected my Camco Rhino hose, pulled the gray water lever and then realized the brand new hose was leaking like Fukushima. Thankfully it was only gray water and I stopped the flow immediately.
Now I gotta wait until the morning to buy another hose.
I had a spare of most everything except the waste hose. Do you guys carry a backup?
07-03-2021, 02:46 AM
I carry 3 sections of hose. Use 2 sections and the 3rd is the backup.
07-03-2021, 04:36 AM
Don't Camp Enough
X2
Always carry an extra waste hose.
2020 Prime Time Sanibel 3102
2016 F-350 King Ranch
07-03-2021, 04:42 AM
Defender of America
Originally Posted by DSMURPHY
X2
This appears to be sound advice. Thanks
Retired USAF
2021 Freedom Express 192RBS
2020 F150 STX 4X4 w/Coyote V8
Centerline TS WDH
07-03-2021, 04:50 AM
Which campground did you go to?
Bruce
07-03-2021, 05:43 AM
I had a brand new Rhino hose once that leaked when new. I had to tighten the end fittings ( reverse threaded if I remember correctly) It worked great after that
Other Motorhome
2013 F-150 Eco-Boost V6
07-03-2021, 06:07 AM
My roughly-eight-year-old Rhino hose finally sprung a leak a few days ago. I drove to the dealer near to me and bought a new Rhino hose. I noticed right away that the new hose is much less durable (both the ends and the hose) than the old one. Somewhere along the way, Camco decided to cut some corners — probably when they came out with the Rhino “Extreme” hose. I doubt my new Rhino hose will have as good of a life as my old one did.
Bruce
07-03-2021, 08:40 AM
I carry a 15 ft. Rhino that is my go-to hose and a 20 ft. Rhino extension hose that I've used as my primary in the past.
I would guess Camco cheapened the Rhino's after they started selling them at Walmart or Amazon.
I learned my lesson with staying with a good name hose after using the "starter kit" hose I received with my current rig, trying to save my Rhino like saving your best shirt for Sunday. The first use of the starter hose it leaked like a cheap lawn sprinkler.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
07-03-2021, 08:46 AM
Where do you store your hose? I installed one of those EZ hose carriers because carrying the waste hose in the bumper beats the heck out the hose.
07-03-2021, 08:50 AM
I have found that some of the Camco fittings connect loosely between two specific hose fittings and leak at the fitting, which all should be standard size. I was able to reconnect the opposite ends of my old hoses and new hises in a way that the fittings were tight all around, so I didn't have to modify anything. I just wonder if the manufacturing of the fittings can be a bit irregular at times. This loose fitment creating a leaky (but new) Camco hose fitting has happened to us twice now.
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
07-03-2021, 09:23 AM
Yep, the collars are reverse threads, and sometimes they come loose due to twisting of the hose and require re-tightening. I make it a point whenever I dump to try and expand the sewer hose with the end caps on. If it is hard to expand, then the hose is sound. If it's easy to expand, then there is a leak, and that requires a closer look. You can do the same thing after rinsing the hose before putting it away in reverse order. I always make sure to never drag the hose across the ground, stones, blacktop or concrete. I always carry a seal kit.
2016 Salem 27RKSS
07-03-2021, 09:36 AM
. . . . we got to the campground about 20 minutes before it got dark. By the time I realized the gray water tank was near full, it was 11pm.
I have never had a problem with the waste hose and have never carried an extra. My current rig - and hose - is 9 years old. Perhaps time to reconsider. ???
I sympathize with your consternation but keep wondering - - if it was your "first shakedown cruise" and you had only been there a few hours (dark - 9ish? - until 11pm) how did the gray water tank get so full so fast? That's 30 gallons.
07-03-2021, 09:45 AM
My current RHINO hose (4 yrs old) with the twist on fittings is beginning to fail (wire rust/breaking).
I go to WM to pick up a new one and notice instantly that the hose thickness is not as robust as the old version (as noted above). Also notice the end fittings are “fixed” and not removable. I have read a few places the fittings leak where the hose is attached. This will not be good since there is no way to remove/tighten/reseal the fittings.
My thinking is that may have to go to the RHINO extreme hose set at roughly 2x the cost.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
07-03-2021, 09:47 AM
Always a good idea to open the black tank valve slowly to start. There can be a lot of pressure on the hose to begin with.
2017 FR3 28 DS
07-03-2021, 09:51 AM
I believe this was Camco’s thinking as well.
Bruce
07-03-2021, 10:16 AM
Which is why I always dump a little grey first. Just in case.
(2014 XLR Viper 305-14) Gone
2020 GD Imagine 2670
2017 Ram 3500 DRW
07-03-2021, 10:37 AM
I've been storing my sewer hoses in the bumper for nearly 20 years and never damaged any hoses.
07-03-2021, 10:45 AM
I switched a couple of years ago to the Prest-o-Fit Blueline line of sewer hoses. They seem to be sturdy and well built. I have several buddies we camp with that use them as well. Just another option.
https://www.prestofit.com/BluelineRVSanitation.html
07-03-2021, 10:50 AM
I usually carry 2(10') sections of Rhino hose and an older 15' as backup but recently as we've camping a lot more and longer since retiring I bought a 5' Section since I found myself many times using a 10' when I could've used a 5' then opening to drain and that 10' uncoiled and jumped off the sidewinder and now I have to hand drain the thing down. In fact I'm using the 5' now, it fits perfect and less to clean.
One last note my Rhino hose leaks here and there but just got to tighten it back into the fittings since it loosens up from usage.
Dana & Terri - (Retired)
Our Cocker Spaniel "Shadow" (6 y/o)
Stephanie (daughter)/Rick/Callie (14 y/o)
Great Granddaughter - Cora (2 y/o)
Great Grandson - Zek (1 y/o)
Phillip (son)/Charlotte (6 y/o)
07-03-2021, 11:39 AM
Originally Posted by shadows4
I went with a blueline about three seasons ago. So far it's working well. It doesn't exactly feel like the greatest hose but it has worked well without any drama. This also fits in my 4-in metal bumper.
