Originally Posted by bikendan
You should be able to use the make and model number of your WH, to find the element replacement.
You probably have a Suburban WH.
Our 2002 Nash (contemporary to your 2003) has an American Standard water heater. It takes the same element as the Suburban, the 1450 or 1500 watt element you can get for about $10 on Amazon. Don't forget to buy the wrench that they offer. You can't get into that space with anything else.
Originally Posted by oaklevel
A picture would help........ on a 2003 are you 100% sure that the water heater is gas / electric ???? Many back then many were gas only.
Certainly not all of them. Our 2002 Nash water heater is both gas and electric. Curiously, unlike the Suburban model, the electric element, thermostat, high-temp cutoff, and off-on switch are all on the inside end with the bypass valves, not outside with the gas gear.
