01-12-2021, 05:40 PM
Instant Pot
We love the versatility of our Instant Pot at home, but wonder if it will draw too much power in our 30-amp camper.
Would love to hear from anyone who uses this pressure cooker on the road.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
01-12-2021, 05:57 PM
Part-Time Campground Host
It will do fine on your 30 amp camper as long as you don't run the AC, hot water heater, toaster, and any thing else you can think of at the same time.....LOL.
Just add up your watts/amps and you can figure what you can use at the same time. We camped in a 30 amp camper for years with no problems.
Craig & Cath
Days camped since 2015(retirement): 1687
01-12-2021, 06:19 PM
They draw a little over 8 amps so you will be fine.
Just follow cboss's advice about use other high amp devices at the same time.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
01-12-2021, 06:46 PM
Should be fine on a 30 amp if you mind other current draws like previously advised.
I've seen a lot of people use their Instant Pot's sitting on the picnic table with an extension cord running to the 20 amp outlet on the power post. Definitely an advantage when releasing pressure as the steam is vented directly outside instead of in the RV.
Also, there are a couple sizes of Instant Pot. Worth checking the individual pot in question as there may be different power requirements.
Just remember that a converter, while charging batteries can draw 700 watts plus, the water heater on electricity another 1400 watts and the refrigerator another 300 watts or so. That adds up so far to 2400 watts and your power supply maxes at 3600 watts.
01-12-2021, 06:59 PM
Just as confused as you
Richard & Jill
01-12-2021, 07:11 PM
Originally Posted by Scrapper
Ha! Better than a crock pot.
Thanks, guys, for all the great info and the timely responses. FYI: my favorite Instant Pot meal is US Senate Bean Soup.
01-12-2021, 07:21 PM
This is what we do. Just be sure not to create a tripping hazard.
01-12-2021, 07:33 PM
Defiantly watch for tripping hazards. I like to use cords with extra length and leave some excess at each end. That way if one does catch the cord with a dragging foot there's enough slack to keep from causing a face-plant as well as not pulling plug out, or appliance off table.
01-12-2021, 07:40 PM
You using it inside or outside? If outside, at your power post, there is usually a separate 20amp duplex receptacle. Plug in an extension cord ran to your outside cooking area and use it. it will not affect the power in your trailer. I use that power outside the trailer in every campsite that has it for outside fans,,ice makers,, decorative lights,, whatever you do outside your camper.
TT: 2018 Coachmen Catalina
243rbs(rear bath) legacy edition
TV: 2022 Ram 2500HD Tradesman
01-12-2021, 08:26 PM
Always Learning
As mentioned, it is fine on 30amps. The only time we ever had issues was trying to use 2 of them at a time on the same 15 amp circuit breaker. We just let one come up to pressure before starting up the second one. I later ran a second outlet to the kitchen which was pulled off of a different breaker.
01-12-2021, 09:06 PM
This can cause problems at some campgrounds. Many times there is a 30A breaker in a locked building that protects the wire from the building to the pedestal. This means that the max current you can draw from the pedestal is 30A regardless of which combination of outlets you use. The issue with this is that it usually requires campground maintenance to reset that breaker.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-12-2021, 09:22 PM
I have both an Instant Pot and an Air Fryer that I use on my trips. I am careful to avoid having the water heater on electric or my coffee maker brewing or my A/C running and of course do not run them together. My Progressive Industries EMS has a display which helps me monitor ampere draw so I can stay under 30 Amps. Well worth having to prepare some nice meals.
Rob Payne
Hendersonville, NC
2018 Rockwood Ultra Lite 2304DS, 10K Equal-i-zer Hitch
2007 Toyota Tundra SR5 Double Cab 4WD 5.7L iForce V8
FROG Member since March 2017
01-13-2021, 09:54 AM
Good point. If there is a separate on/off switch for the 20 amp, does that mean the problem you describe would not be a factor? Thanks.
