IRV-70 Technologies Radio/DVD.- clock problem
I am trying to do something as simple as setting the time correctly on the clock. I can set the hours according to the directions but I cannot set the minutes. I have read other posts and obviously this is a problem because everyone says "I give up." Well now this has become a problem for me because I am determined to get that clock set correctly!! Just checking to see if anyone has figured out the correct way to set this. It says to press clock and hold for 3 secs and it will flash and use the select knob to set the hour. Now it does this no problem. Now you move on and press select again for the minutes and use the select knob to set the minutes. This is the part that does not work. When you press the select knob again it just reverts right back to the hour instead of moving on to the minutes. Can anyone help me? I wont be able to sleep until I get this working. LOL Cindy
2018 Rockwood Ultra Light 8289WS Fifth Wheel
2017 2500 Dodge 6.7 Diesel
