IVR 32 Issue with Samsung TV
Hey Joe,
Mute is not ON, Volume not at Lowest Setting. TV is on HDMI-2
Also tried the reverse of the above, but to no avail.
I did see something I hadn't noticed before, that is, I see an iVR icon on my screen but it doesn't do anything when I select it.
One other note: I have to turn the TV off then back on again to get the sound to come out of the TV.
I've logged a call to iVR and will be interested to see if and when they respond.
Also will try to get an operator's manual for the TV
My Samsung TV model number is: UN43J5202AF
2014 Ford F250 SRW 4X4 Crew Cab
Lariat 6.7L Power Stroke V-8 Diesel
Equal-i-zer WD system- 12K lbs GTW, 1,200lbs TW
