Old 08-31-2020, 09:12 PM   #1
Is this an antenna and what's it for?
On my new 2021 salem fsx 179dbk I noticed this and was wondering what it is. There is no paper work on it and I can not find anything that looks just like it on the web. Thanks
Name:	what is it.jpg
kthornton is offline   Reply With Quote
Old 08-31-2020, 09:30 PM   #2
Yes that is your tv antenna should be a dial underneath it to turn it in the direction of the best signal in conjunction with the amplifier
MedicJim is offline   Reply With Quote
Old 08-31-2020, 10:16 PM   #3
No rotation on this style of antenna, it’s a permanent mount, omnidirectional.
Bob_T329 is offline   Reply With Quote
Old 08-31-2020, 10:21 PM   #4
LittleBill's Avatar
Definitely a directional antenna. Going by your picture, it doesn't look like it is a King, think it may be a Winegard Rayzar z1 (going by the base of the antenna in the picture) - https://winegard.com/industry/recrea...ayzar-z1-white
Here is a link to the operation guide for the Winegard Rayzar - https://d38mfwkkxtsm2m.cloudfront.ne...ts/2452370.pdf
Hope this helps. Good luck.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 08-31-2020, 11:08 PM   #5
Need a closeup picture, but it looks a lot like ours. As MedicJim says, it may have a dial on the ceiling with lights around it that indicate signal strength. Or it may be an omnidirectional. They seem to use the same housing on different antennas.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-01-2020, 07:37 AM   #6
It looks a lot like our Rayzar Z1, but I don't see the little elements on it, so it may be a knockoff or it just may be turned away from the photo.
Which wall plate do you have for it? If it's the Sensor Pro you need to get the manual and learn how to use it to get the best reception.
Gotta go campin!
Old 09-01-2020, 09:56 AM   #7
20RDSE Antenna
This appeared to me to be the same style antenna on my 20RDSE which I know is an omnidirectional style antenna. Clearly there are lots of models out there with different options.
We've owned almost every style camper there is over the past 35 years, I have to say I was less than thrilled with this "new" style antenna on our new unit, however I've been pleasantly surprised at the additional; channels it picks up over our other units.
Old 09-01-2020, 02:06 PM   #8
DustyRoads's Avatar
Looks like mine. It is Omnidirectional. No ability to turn it. It has terrible reception. If I watched much TV in the trailer I would replace it.
2017 Forest River Surveyor 251rks
2016 Chevy 2500HD
DustyRoads is offline   Reply With Quote
Old 09-01-2020, 02:14 PM   #9
Omnidirectional, No adjustment, worst Antenna ever made.
TheWolfPaq82 is offline   Reply With Quote
Old 09-01-2020, 07:09 PM   #10
This is the (not my pic) plate on the inside. I agree it's an omnidirectional antenna but I can not find one that looks like it or the plate. I will try to get better pics of the antenna. It did not come with any documentation. Thanks for all the replys.
Old 09-01-2020, 07:15 PM   #11
Georgia Rally Coordinator
aceinspp's Avatar
Its a piece of junk. Maybe you can find a way to replace as ther is no adjustment to turn to find channels. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-18 days
aceinspp is online now   Reply With Quote
Old 09-02-2020, 10:20 AM   #12
That plate says 'King' on it, so if that's exactly the plate you have you also likely have a 'King Jack' antenna. King does make an omnidirectional antenna and that may be what Salem used on these RV's.
After looking at some pictures of the RV, it looks like it'd be easy to replace it with a directional antenna that could be rotated.
Gotta go campin!
Old 09-02-2020, 11:13 AM   #13
To answer the question in the thread title, it is an antenna and it is there for driving you nuts while you try to figure out why your television doesn’t get many channels.
I hate these low profile omnidirectional antennas, they just don’t get the reception of a crank up rotatable directional antenna. The one on our motor home is within an inch of the AC so anything to the curb side is blocked from the antenna. Poor choice, poor design, poor location.
2021 Coachmen Freedom Express 246RKS
2022 F150 Powerboost Hybrid.
DougW is online now   Reply With Quote
Old 09-10-2020, 08:51 PM   #14
looks like the same POS I have. Been wondering how to convert it to a directional. Would appreciate it is someone knows how.
2014 Cherokee Grey Wolf
2016 Lariat Screw w/3.5 EB
cajun bill is offline   Reply With Quote
Old 09-11-2020, 12:06 AM   #15
My king omnidirectional picks up a lot of channels. We were 20 miles outside of Madison. Wi. And I picked up about thirty channels. Basic 2. 5. And 7 for local morning news. Was made aware of i90 shutting down about 40 miles down. We made a detour and missed it all. I think someone may have mentioned past post of the different region you are in. We also picked up a bunch just outside of Austin. 50 miles? Just my 2 cents.
Freon is offline   Reply With Quote
Old 09-11-2020, 05:39 AM   #16
Looks like the piece of garbage that was installed on top of my camper, too. Anybody have any suggestions for a replacement that actually will pick up a channel?
ibicycle is offline   Reply With Quote
Old 09-11-2020, 07:06 AM   #17
I replaced ours with a Winegard Rayzar Z1 and it does a much better job. The king jack would also be a good choice.
It requires you to drill a hole in the ceiling, but that's not a big problem.
I removed the omni antenna and took an ice pick put it down through the existing hole and punched a small hole in the ceiling below. That makes sure the hole in the ceiling is lined up with the existing hole on the roof. Then just use a hole saw to drill a hole in the ceiling. Just make sure that you don't damage the coax as you'll reuse that. Then mount the antenna according to the instructions.
I also replaced the OEM wall plate (splitter/power supply) but the OEM one should work with most antennas.
Gotta go campin!
Old 09-11-2020, 01:41 PM   #18
The plate also served as a power injector for the antenna. Turning it on should improve reception.
EseLoco is offline   Reply With Quote
Old 09-11-2020, 03:45 PM   #19
RichB
The picture of the wall plate shows what looks like a small button, and says on/off. The omni-directional TV antenna only works well when the power button is 'ON', which powers up the antenna booster amplifier. To watch over the air TV, the power button must be 'ON', to watch cable, the power button must be 'OFF'. The booster also helps FM radio reception.
RichB is offline   Reply With Quote
Old 09-13-2020, 01:03 PM   #20
Agree 100%. Junk. Can’t get tv worse yet cant get any radio stations. JUNK
Ken1967 is offline   Reply With Quote
antenna
