06-09-2022, 08:28 AM
Is this normal
2022 F.R. Wildcat 5th wheel. Obvious newbies.
Pulled into south Louisiana yesterday afternoon. Park has a lot of trees. When parked we leave the bathroom vent open, not sure why we just do, and keep bathroom door closed. When we woke up this morning there was condensation all over the bathroom ceiling and some on the hall just outside the bathroom.
This can’t be good.
06-09-2022, 08:50 AM
I would guess that its normal. The moisture in the air was able to come down into your RV through the open vent. With the bathroom door closed, the humidity was concentrated in the bathroom. I assume you were running the A/C, which cooled all of the surfaces, and the humidity became condensation. Like a cold drink, and the outside of the can, or glass gets wet.
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
06-09-2022, 08:51 AM
With high humidity and leaving the vent open, yes I would not at all be surprised.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
06-09-2022, 08:54 AM
Guitar G
Humidity Tips
We saw this video from Tod at NRVTA recently about controlling humidity in an RV. One of the tips was to leave your windows closed when there is high humidity outside. Leaving the bathroom door open rather than closed would probably be good, too, since the bathroom is a high-humidity area. Here's the link to that video.
Jan & Gary
Exton, PA
2021 Flagstaff SuperLite 26RBWS
2019 Ford F-150 3.5L EcoBoost
06-09-2022, 09:00 AM
I agree, if the fan was off or even on (being a cheap 50 cent vent fan). Louisiana is known for its crawdads and humidity.
For piece of mind, leave the vent closed to see if it happens again.
2023 3/4 ton Chevy Silverado Diesel
2024 Grand Surveyor BHXL 240. 400 watts solar, 2000 watts pure sine inverter, 30 amp controller and remote 2-100ah LiFeP04 in parallel
06-09-2022, 09:39 AM
We leave our bathroom vent open a lot (no fan running unless we are showering) and at night especially, the ceiling gets wet as the A/C is running thru vents in the ceiling and the condensation forms accordingly.
I don't worry much about it....just wipe it off and carry on. Not worried about moisture in the "attic" as there are attic vents.
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
06-09-2022, 02:30 PM
Close your vents, run ac, get a good dehumidifier and a couple fans to circulate the air
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
06-09-2022, 03:44 PM
This can’t be good.
We leave our bathroom vent open most of the time, with the MaxxAir can on the lowest speed and three for closed. In extreme heat (like maybe Louisiana?) the AC wouldn't be able to keep up, but it keeps the air circulating and would prevent the condensation you described, because there would be positive pressure blowing out at all time.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
