05-06-2018, 03:34 PM
Is Water Filtration Necessary?
Hi everyone!
We retire at the end of May and are so excited to start using our fifth wheel extensively!
While thinking about our needs and additional items that might be nice to have, I wondered if having a water filter in-line with the kitchen, shower and lav. makes sense if we don't drink the water from these sources. Our Culligan filters only offer 250 gallon usage and I don't see the need to have this filtered water for dishes or showers. For drinking we use hard-sided water bottles that have filers built in to them. Is the primary purpose of a whole RV filter to help extend the life of the water pump or for possible water consumption?
Thank you!
2016 Rockwood Signature Ultralight 8289WS
2015 Ford F-250 Lariat Super Duty Crew Cab, 4X4, 6.2L V8
05-06-2018, 03:45 PM
Location: Alberta - East of the Rockies, West of the Rest
IMO, a whole house sediment filter to keep the plumbing safe and a countertop Berkey water filter for drinking water should be sufficient.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
05-06-2018, 04:03 PM
I agree that generally, all the water going through a fine 5 or 10 micron expensive filter is not necessary. Can you tell me about your sediment filter? Is it outboard like my current Culligan filter?
05-06-2018, 05:39 PM
It's one of these, just to catch the gravel.
https://www.amazon.ca/Camco-40045-Ta...79KZ4HQVVKK8FV
Our previous trailers had a FR1 filter inside the basement storage, there are reports of them breaking or falling off, we never had this problem.
Ordered: 2021....
05-06-2018, 05:51 PM
But $46 CDN for 2 filters (or 1 year if you're having extended seasons) seems rather high. Gotta be a less expensive filter @ 100 microns. Thank you!
05-06-2018, 05:57 PM
Mmh interesting, it showed me something like $34, I think we paid $13 at Walmart - don't quote me.
Ordered: 2021....
05-06-2018, 06:06 PM
That's certainly reasonable at $13 or even $20. I just found these at $10.49 US for a 4-pack.
https://www.amazon.com/1M-4PK-1-Micr...ilter+sediment
It says reverse osmosis. Is that compatible?
05-06-2018, 06:08 PM
Hi everyone!
Thank you!
The built in water filter is between the pump output/shore input for filtered water to the fresh water plumbing system (water heater/toilet/faucets/shower etc.), thus a whole house filter. It has nothing to do with prolonging the life of the water pump. I like the built in filter and it uses the simple 10" inexpensive ($8) 2 pack carbon filters.
05-06-2018, 06:38 PM
It could be compatible with a small under sink system, IDK.
We had a whole house RO system on the farm, where the replacement filter was $1,300 every 3 months but the water would still make you glow in the dark (50 ppm uranium from 360' depth, aquifer from the earth's middle ages).
The reason we use a filter at all is just to catch particles that could plug the aerator screens in the taps or get stuck in the water pump when we use the freshwater tank.
We drink unfiltered water from our own well (not the well on the farm), on the road we use a Travel Berkey for drinking, coffee, cooking.
Ordered: 2021....
05-06-2018, 06:43 PM
It depends on the setup.
When you fill the freshwater tank externally then you're right, but if the water system is configured to fill the tank through the city inlet then it would likely pass through the filter.
Ordered: 2021....
05-06-2018, 06:51 PM
I re-looked at the Culligan filters prices and found some that were only $10.50 US currently. I was wondering if it might just be easier to eliminate the whole filter from the water inlet, but I think your caution about sediment and "gravel" are worth leaving the system in. Thanks for all your inputs!
Dale
05-06-2018, 07:12 PM
Could be. So is the valve selection before or after the filter? Still wont help the pump.
05-06-2018, 07:20 PM
Hi everyone!
Thank you!
To answer your original question is a water filtration system necessary the short answer is................ no.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
05-06-2018, 07:41 PM
I've had 2 houses (1 well, 1 city), 1 RV, and 1 boat all with whole "house" sediment filters. Looking at the filters after a few months in use has convinced me sediment filters, at a minimum are a really good idea. If consuming the water, testing including a bacteriological test, is also a good idea. (I use UV on the home well and bottled water elsewhere.)
2017 Riverstone 38FB Legacy
2018 F450
05-06-2018, 07:44 PM
I was trying to say, that if you can catch sand particles before they enter the freshwater tank in either an internal or external filter than they sure will not get into the pump.
The filter should be before the selector valves. Having said this, our current trailer does not have an internal filter, this is why we use an external one. Our previous trailer did have an internal filter before the selector valves but an external tank fill. The trailer before that one had an internal filter right behind the city water hookup from where the freshwater was also filled. In a nutshell, it's all over the place.
Ordered: 2021....
05-07-2018, 01:13 PM
WE use those same filters. They actually are higher rated than most if not all of the filter elements in the larger canister type filters. WE camp one extended weekend a month and change them each year at the start of camping season, (like 2 weeks ago)
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
05-07-2018, 02:53 PM
From multiple Forum issues on this and related topics, I conclude the overwhelming number of RVers never drink the water that comes out of the faucets. However, if you have a tank type filter or have concerns about grit affecting valves and faucets, then a particulate filter may be a nice add-on, but I don't think there is a cartridge filter on the market that filters bacteria if that's your concern.
2018 Berkshire 38A
05-07-2018, 02:57 PM
https://www.usautoauthority.com/best-rv-water-filter/
Read #1, Best of the Best, you may be in for a surprise.
05-07-2018, 03:00 PM
I politely disagree.
In my 15 years of being on various RV forums, I would estimate the majority of RVers will use a water filter for city water and will drink faucet water.
Carrying bottled drinking water is a waste of money and weight and creates a waste nightmare.
Many of us grew up drinking out of a garden hose and aren't part of the current cultish obsession with bottled water.
And it's well proven that the majority of people will pick city water, over bottled water, in many taste test studies.
05-07-2018, 04:22 PM
Hi,
I confess to RVing for 40+ years, camping all over the country, never filtering water, and never suffering adverse effects. Guilty on all counts.
But I also know that different people have different physiologies, which can make them sensitive to water varability. And others have different psychological makeups, when it comes to comfort level about using strange water sources.
Compared to the cost of most rigs, filter systems are cheap. By all means, use them if they increase your enjoyment of your camper.
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
