I had the same issue when I first installed mine.
I could lift my side of the landing gear with great effort but the DW couldn't lift her side.
I found I had tightened the attaching bolts (at the ends of the arms) just a tad too tight.
Once I found where there was no slop in the connection but not too tight, our problems went away
A periodic squirt of dry spray lube helps too. Make sure you spray up inside where the tubes telescope on both the Strongarms and the landing gear.
Days Camped: '18=48 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=112 ☼ '23=83
