Old 07-06-2017, 02:34 PM   #1
King antenna on 2017 Champagne
Antenna seems to be inferior as I cant get good coverage. Any ideas for a better antenna or an upgrade to this one? The one i have is the standard for a Champagne. Does not have any lights or booster that I can see.
pfish48 is offline   Reply With Quote
Old 07-06-2017, 08:56 PM   #2
SeaDog's Avatar
the old gold standard is the wineguard batwing antenna it has been around for years and gives great reception.
Retired Navy
2016 Flagstaff 26 FKWS
Old 07-07-2017, 11:57 AM   #3
capriskier's Avatar
We are having the same problem with our antenna on the same camper. The antenna does not go up, it just moves around in a circle. We cannot pick up any channels.
capriskier is offline   Reply With Quote
Old 07-07-2017, 12:46 PM   #4
I'm taking mine back to dealer. Antenna doesn't work nor does the cable jack in the outside compartment. Am installing the direct tv satellite on roof too. Can't believe they put all the connections behind the heavy 60" tv!
Old 07-07-2017, 03:39 PM   #5
Kenny kustom's Avatar
My jack sucks compared to the batwing on my old unit.
2017 Dynamax Isata 4
Old 07-08-2017, 06:22 PM   #6
TandSH's Avatar
Wow, such different experiences from us.
Raising a batwing 2' or so will not improve reception, and they are very fragile. (I destroyed one when it caught on some Spanish moss hanging from a limb). My experience to date is that the King antenna (now on 2 different campers for us) has better reception and is not as directional as a batwing.
For any 'over the air' reception system I have found the smartfone app DTV Antennas to be most helpful in aiming whatever antenna you have.
2017.5 Cedar Creek 34RL2
2018 F-350 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
Old 07-08-2017, 07:28 PM   #7
King of the Road
X2 this. I immediately replaced the Winegard batwing on my rig with the King Jack. Get's much better reception now.
If your antenna is just going round and round and not up, it's not the antenna's fault, it the mount. Something is wrong and needs to be checked.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
Old 07-08-2017, 07:34 PM   #8
King of the Road
The new LED televisions are by no means heavy as compared to how an old 35inch console TV was in the day.
I can handle my 40" Samsung by myself and mounted it on my own. With a 60", it's probably more awkward than heavy and two people should be able to take it down to get to the connections and put it back up with little effort.
2016 Crusader Lite
Single slide
Old 07-08-2017, 08:47 PM   #9
the booster button is behind living room tv in the 38el
dustycreek2 is offline   Reply With Quote
Old 07-08-2017, 08:48 PM   #10
I remote extended all the TV Jack's to a nearby cabinet. The batwing antenna is my preference because it is directional.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 07-08-2017, 09:15 PM   #11
jtatum65's Avatar
Just curious, but did any of those having problems getting good reception with your King Jack antenna actually read the manual? It states to turn on the antenna booster, where ever that maybe in your camper, turn on the signal meter (switch is on the side of the rotating knob) with the db gain turned all the way down, then turn antenna until you get the strongest signal and then turn the gain back up to achieve maximum signal strength. I am on my 2nd Jack antenna and as others have stated this is a far a better antenna the the old crank up and hope you remember to lower it before pulling out of the campground.
Jim & Evelyn Tatum
2023 Columbus River Ranch 391MK
2022 Dodge Ram 3500 Big Horn Diesel
Nights Camped 2023 = 30
Nights Camped 2022 = 40
jtatum65 is offline   Reply With Quote
antenna
