Originally Posted by bubbles
I just assumed you had the Forest River KW-1 canister but if you have the regular threaded canister then any standard 2X10 inch filter will work. 2 for $8 at Lowes so just get one and see if it works. There is no need to replace your canister if this is true.
Sorry, I think I even confused myself with my post. It is the WaterPur RCS canister that takes the KW-1 filter. I just went out and raised the cover to take some pics and clear it up in my own head. This model does not have the notched threads up in the base and does not need pushed up on to remove or install, just threaded on.
But while I had it apart and looking up into the base, I can see no way that filter in their listing could seal against any flat surface. So guess I have answered my own question and it will not work. Now wondering what KW-1 housing it would actual fit? If any?
Thanks again for the replies.
